Trizum Posted May 13, 2004 Share Posted May 13, 2004 Hi, I am a new and happy user of Opera 7.5... however I am having one big problem. With links that are associated wiht IRC, I cannot click them because opera doesn't support the irc:// type of link... Is there anyway to fix this? Thanks a lot. TGx :D Link to comment https://www.neowin.net/forum/topic/166896-opera-%09irc-link-problems/ Share on other sites More sharing options...
trigger_my_passion Posted May 13, 2004 Share Posted May 13, 2004 #opera in irc.opera.com log: [17:34]<trigger_m> hello[17:34] <trigger_m> how to have opera handle irc:// links [17:34] <TarquinWJ> trigger_m: it does not do that yet [17:35] <TarquinWJ> it probably will do it in a future release Link to comment https://www.neowin.net/forum/topic/166896-opera-%09irc-link-problems/#findComment-2103778 Share on other sites More sharing options...
Trizum Posted May 13, 2004 Author Share Posted May 13, 2004 Thanks! :D Link to comment https://www.neowin.net/forum/topic/166896-opera-%09irc-link-problems/#findComment-2103792 Share on other sites More sharing options...
Trizum Posted May 14, 2004 Author Share Posted May 14, 2004 Wow, Opera's tech support isn't very smart: If you add irc to Preferences > Programs and Paths >> Protocols, set it to 'Open with this application' and enter the path to mIRC. It works just fine. So muhc for tech support. :blink: This is the fix. :D Link to comment https://www.neowin.net/forum/topic/166896-opera-%09irc-link-problems/#findComment-2108211 Share on other sites More sharing options...
trigger_my_passion Posted May 14, 2004 Share Posted May 14, 2004 I have to add that TarquinWJ wasn't one of the official Opera guys. He was just a voiced user there. Link to comment https://www.neowin.net/forum/topic/166896-opera-%09irc-link-problems/#findComment-2108224 Share on other sites More sharing options...
