mattoneill Posted May 31, 2004 Share Posted May 31, 2004 hi guys, is it possible to monitor the bandwidth when just using a cable modem and linksys router? (i.e. no server pc) cheers Link to comment https://www.neowin.net/forum/topic/172648-bandwidth-monitor-when-using-a-link-sys-router/ Share on other sites More sharing options...
MxxCon Posted June 1, 2004 Share Posted June 1, 2004 www.linklogger.com Link to comment https://www.neowin.net/forum/topic/172648-bandwidth-monitor-when-using-a-link-sys-router/#findComment-2195015 Share on other sites More sharing options...
GNRambo Posted June 1, 2004 Share Posted June 1, 2004 If you have sympatico go to self care then bandwith usage Link to comment https://www.neowin.net/forum/topic/172648-bandwidth-monitor-when-using-a-link-sys-router/#findComment-2195030 Share on other sites More sharing options...
mattoneill Posted June 1, 2004 Author Share Posted June 1, 2004 what is sympatico? Link to comment https://www.neowin.net/forum/topic/172648-bandwidth-monitor-when-using-a-link-sys-router/#findComment-2197337 Share on other sites More sharing options...
dotRoot Posted June 1, 2004 Share Posted June 1, 2004 what is sympatico? a Canadian ISP. Link to comment https://www.neowin.net/forum/topic/172648-bandwidth-monitor-when-using-a-link-sys-router/#findComment-2197356 Share on other sites More sharing options...
mattoneill Posted June 1, 2004 Author Share Posted June 1, 2004 ohh right no im in the uk, on ntl Link to comment https://www.neowin.net/forum/topic/172648-bandwidth-monitor-when-using-a-link-sys-router/#findComment-2197359 Share on other sites More sharing options...
Adrian Posted June 1, 2004 Share Posted June 1, 2004 If you have a Linksys WRT54G you might be able to get a away with putting Wifi-Box firmware on the router and enabling SNMP and use an SNMP client and monitor the bandwidth. Link to comment https://www.neowin.net/forum/topic/172648-bandwidth-monitor-when-using-a-link-sys-router/#findComment-2197365 Share on other sites More sharing options...
dotRoot Posted June 1, 2004 Share Posted June 1, 2004 That's alright, I'm not in Canada either. Also you can probably use an MTRG monitor, those are really made to monitor bandwidth straight from the switch. Link to comment https://www.neowin.net/forum/topic/172648-bandwidth-monitor-when-using-a-link-sys-router/#findComment-2197366 Share on other sites More sharing options...
+BudMan MVC Posted June 1, 2004 MVC Share Posted June 1, 2004 if your linksys router (you did not give model) supports snmp - not all of them do. Then yes mrtg http://people.ee.ethz.ch/~oetiker/webtools/mrtg/ is a sweet way to monitor the traffic in and out of your router. Link to comment https://www.neowin.net/forum/topic/172648-bandwidth-monitor-when-using-a-link-sys-router/#findComment-2197664 Share on other sites More sharing options...
Adrian Posted June 1, 2004 Share Posted June 1, 2004 Just installed PRTG and it works in conjuction with SNMP on my router (Linksys WRT54G) Link to comment https://www.neowin.net/forum/topic/172648-bandwidth-monitor-when-using-a-link-sys-router/#findComment-2197672 Share on other sites More sharing options...
