l77Il7H Posted June 7, 2004 Share Posted June 7, 2004 (edited) i hate HATE setting up those stupid little jumpers for the mobo. the one that say power, rest, HDD, etc. there so small, makes them hard to handle, and i still can't figure out which wire is + and -, lol! recently a lot of mobo been color coding their jumper area to make it more simple. i thought it was a great idea. so i came up with this idea to make it even more simple, color the damn jumper wire itself! everyone will have to adopt the color scheme, which will be a challenge, but it's totally worth it. minor adjustement from spikepringlesbro's suggestion Edited June 7, 2004 by l77Il7H Link to comment https://www.neowin.net/forum/topic/175299-ideas-for-setting-mobo-jumpers/ Share on other sites More sharing options...
SpikePringlesBro Posted June 7, 2004 Share Posted June 7, 2004 pretty good idea :D you should also get different shades of the same colour so you know which is + or - ie. a darker shade = minus and a brighter shade = plus :) cool idea :yes: Link to comment https://www.neowin.net/forum/topic/175299-ideas-for-setting-mobo-jumpers/#findComment-2236164 Share on other sites More sharing options...
PCKing Posted June 7, 2004 Share Posted June 7, 2004 look on the side that is not labeled and you will see a little arrow over the +... simple enough if you ask me and I have large hands. Link to comment https://www.neowin.net/forum/topic/175299-ideas-for-setting-mobo-jumpers/#findComment-2236265 Share on other sites More sharing options...
