help! corrupt gfx radeon 9700 pro ss included
hey
can someone please help i keep on recieving corrupt gfx in desktop,games and everyother app, i have re-installed windows on multiple occassions trying everything from 98se to windows xp, all have the same problem so it is obviously something to do with the hardware or a conflict in hardware,
these are my specs:
motherboard: GA-7N400L F10
processor: AMD Athlon XP 2600+
graphics card : hercules radeon 9700 pro
ram : 1 gig ddr 3200
audio: nforce onboard 6 channel
screenshot
hey, i tired another gfx card a geforce 2 64mb worked fine, i ordered it from dabs.com where it is under warranty but not an instant return one so i now have the hassle of returning it and waiting probably half a year or something stupid for the return. shame cuz it was my 16th b'day present and i only 16 so dont have the money to just buy a new one. well i best get returning it. :(
do get that when ur in the bios and windows loading?
if u do then switch off your pc and then switch it back on and it will be gone. if its just windows then its gonna be drivers. i had that happen to my 9700pro and i just switched my pc off for 30secs and switched it back on. and it worked fine.
hey, yes it happens in dos aswell, switching my pc off for around 5 mins solves the problem but then after a bit the problem comes straight back, i have tried about every compatible radeon driver made and all have the same effect, but sometimes problem originates in DOS or BIOS aswell so i am thinking it is more hardware rather then software.
