Hi all...I have been wondering for some time now (and I suppose I could just as easily test this out...but...
I want to eliminate as many of the fonts in my "fonts" folder as possible....I know the system requires a decent amount for various displays and what not......but what bugs me a lot in the folder are all the "bold" and "italic" versions of fonts.
About 3 years ago I tried minimizing the folder only to get an error because I had deleted Tamoha...which at the time I didn't realize was important.
Anywayz...my question is.....Is there any way to check to see if any programs specifically need a font..........or if not....is it safe to delete such fonts as "Arial Narrow" and "Arial Black"....of course I'll keep "Arial" ...but the extras....are they needed?
https://www.neowin.net/forum/topic/205839-help-minimize-fonts-folder/
Here you go...
____________________________________________________________________________
C:\WINDOWS\Fonts
Sometimes .fon extension fonts (The red A fonts) hide, so you need to run a search for *.fon in Search Assistant.
Open your Search Assistant. Be sure under "More Advanced Options" you have "Search for hidden files and folders" selected. Do a search for *.fon
About 138 of these Fonts should show up.
Now, highlight these specific 15 Fonts...
cga40woa.fon
cga80woa.fon
coure.fon
dosapp.fon
ega40woa.fon
ega80woa.fon
modern.fon
roman.fon
serife.fon
smalle.fon
sserife.fon
symbole.fon
vgafix.fon
vgaoem.fon
vgasys.fon
At the top of your Search Assistant click on "Edit". Scroll down and select "Invert Selection". Now delete all at once the other 123 unnecessary Fonts.
TTF Font Extentions:
Here is a list of the 22 remaining *.ttf Fonts I have in C:\WINDOWS\Fonts. To see them all, because some are hidden, you need to do a search with your Search Assistant for *.ttf
You can do the Search Assistant trick above to keep these and remove all the others.
arial.ttf
arialbd.ttf
arialbi.ttf
ariali.ttf
courbd.ttf
lucon.ttf
marlett.ttf
micross.ttf
tahoma.ttf
tahomabd.ttf
times.ttf
timesbd.ttf
verdana.ttf
verdanab.ttf
verdanai.ttf
verdanaz.ttf
These could not be removed on my new system since I bought this new computer even in safe mode, so I also keep these three now:
trebuc.ttf
trebucbd.ttf
trebucbi.ttf
trebucit.ttf
These 2 Fonts I think SP2 holds dearly now, because they will not delete for me as they did with SP1:
framd.ttf
framdit.ttf
So I'll just keep them too.
