col_sandurz Posted August 22, 2004 Share Posted August 22, 2004 When I right click a file i get all the standard options like copy/paste, open, open with, properties, create shortcut, delete but I also have other options from sofware I've installed like winrar, I'll see winrar's "add to archive" option. How do I get rid of these extra options? Link to comment https://www.neowin.net/forum/topic/207041-right-click-menu/ Share on other sites More sharing options...
erp Posted August 22, 2004 Share Posted August 22, 2004 winrar is customizable. Options-->Settings-->Integration-->context menu items Link to comment https://www.neowin.net/forum/topic/207041-right-click-menu/#findComment-584407923 Share on other sites More sharing options...
todd Posted August 22, 2004 Share Posted August 22, 2004 I'd like to know where this tidbit of information is hiding in the registry too. Link to comment https://www.neowin.net/forum/topic/207041-right-click-menu/#findComment-584408669 Share on other sites More sharing options...
NightCrawler Posted August 22, 2004 Share Posted August 22, 2004 Have a look at: HKEY_CLASSES_ROOT\Directory\shell HKEY_CLASSES_ROOT\Drive\shell HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Directory\shell HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Drive\shell HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*\shellex\ContextMenuHandlers NC Link to comment https://www.neowin.net/forum/topic/207041-right-click-menu/#findComment-584408746 Share on other sites More sharing options...
Jimmie Posted August 22, 2004 Share Posted August 22, 2004 You might want to check out this program: ShellExView Link to comment https://www.neowin.net/forum/topic/207041-right-click-menu/#findComment-584408854 Share on other sites More sharing options...
icecaveman Posted August 22, 2004 Share Posted August 22, 2004 jrzycrim said: You might want to check out this program:ShellExView agree, very useful, also check out the other utilities by the same author they are super although they don't look like much Link to comment https://www.neowin.net/forum/topic/207041-right-click-menu/#findComment-584408870 Share on other sites More sharing options...
insanekiwi Posted August 22, 2004 Share Posted August 22, 2004 thanks for shellex. awesome program. Link to comment https://www.neowin.net/forum/topic/207041-right-click-menu/#findComment-584408874 Share on other sites More sharing options...
imtoomuch Posted August 22, 2004 Share Posted August 22, 2004 (edited) I'll have to check this ShellExView app out. This would be much easier then editing each file extension individually in the registry. EDIT: This app isn't exactly what I thought it would be. Edited August 22, 2004 by imtoomuch Link to comment https://www.neowin.net/forum/topic/207041-right-click-menu/#findComment-584408898 Share on other sites More sharing options...
