Help setting up RoadRunner with router
ok the cable dude just came in and setup my cable modem service from roadrunner
the modem is a toshiba PCX2200 and i have a netgear Wireless Router MR814v2
when i hook up the cable modem directly to the computer it works fine, but when i hook it up to the router it doesnt, i have it set up to require no login and get IP from ISP and get DNS from ISP auto
account name and domain name i left blank because i dont think those are required.
any help would be appreciated
Unplug the power to the cable modem for about 20 seconds and then plug it back in. Make sure it is connected to the router when doing this.
Also make sure your ethernet wires are going into the correct ports.
That's the way it's supposed to be, isn't it? Use DHCP to get that info automatically?
I have road runner, and the exact same modem, but not a wireless router.
ahh thanx that did the trick :D
ok ive been testing my connection, but im getting horrible results i assume.
when i go to dsl reports, i see people with test ranging above 2 megs
when i did mine it ranged around ~300k, wtf is up with that?
Is your wireless NIC a Netgear WG311?
What the fux0r is roadrunner?
I have heard about a roadrunner computer but is this some kinda net connexion?
Yes, it's an cable internet service through Time Warner :D
