Problem with task manager
Ok, when I press and hold ctrl+alt+del it says "Tast manager has been disabled by your administrator" when I'm in fact the Administator! Is there anyway to resolve this, it's become quite annoying :(
Ps: I'm on XP Home
SCV its hard to delete when you can't use regedit I'm seeing if Ad-Aware can pick it up and delete it.
Edit: Hmmm it seemed to have delete it but Bazooka Scanner still detects it, I'm gonna try rebooting.
search this FORUM for task, username: forcer, i made a post about it a few weeks ago also posting how i fixed it, ad-ware wont fix it but i suggest running it anyway to getrid of what may have caused it, basically al this virus/trojan/whatever does is adds a registry key
i had this virus, last week i didnt post here, but mean also disabled regedit and msconfig.
so had to make a VB file to enable regedit.
To enble it run > regedit > Ctrl + F > task manger > look for one to enble it i spoted it strigh awy carnt rember witch one it was
Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
