Folder problems
Ok, in my folders, one can organize files, by name, size, type, and modified.
However, in "my shared folder", the one I download all my media too, I can organize by name, size, modified, created, and accessed. I'd like to orgnize by type, but theres no option to do so like the other folders. how do i fix this?
The only method I can think of is creating a new folder, make sure it can sort by type, and then move all the files from the old folder to the new one. Other than that, I have no clue.
Just change your folder view to details, right click on the little bar
where it says, " Name, Size, ..." and make sure type is checked.
Then change you view back to what ever you like.
584709384[/snapback]
Type wasnt selected. Thanks its fixed!
