HL2 Problem
hi all
im playing hl2 and im towards the end of (i think) "we dont go to ravenscroft"
gone through the town
been trhough the mines
and along the train tracks to where you go inside
the black guy says "over here dr freeman" pause for a sec (not literally pause, just as if he's waiting) and then again "over here dr freeman" even though im standing right infront of him, just continuously looping.
i can move around shoot my gun etc, but it wont let me move on
any help would be appreciated, i've registered on steam forums but my account is "awaiting activation" ;/
ta
https://www.neowin.net/forum/topic/245963-hl2-problem/
bump... i know leave it awhile..... but ppl are probably tired of talking about it, now that they can actually play it but im stuck and I WANNA PLAY TOO! lol
edit: here's a screenie of where im stuck
https://www.neowin.net/forum/topic/245963-hl2-problem/#findComment-584946618
did try no clip but wont let you continue with the game :(, i had to reinstall pc anyway last night so ive started from the beginning again and this time ill just jump throught the window.... just in case, cos that seemed to have worked for every1 else
https://www.neowin.net/forum/topic/245963-hl2-problem/#findComment-584956824
  Dennis said:
I continued just fine without jumping through any window. The guy moved on and I followed him.
584957020[/snapback]
Same,
When I got to that part and he said a sentance and then he stopped. and I thought "weird" but after 4 seconds he said something else and walked over to the radio.
https://www.neowin.net/forum/topic/245963-hl2-problem/#findComment-584957065
  • 3 years later...
...I'm also stuck here. I've tried everything PHiZZy has tried, plus jumping through the windows, noclipping. Nothing works.
There must be a console command that will force the Leon NPC to continue with his script, so he'll open the door and allow me to continue. We'd sure appreciate it if someone knows what that command is, or if there's a fix for this bug...'cause according to Google this thread is the *ONLY* place on the 'net where this problem has ever been discussed :D ...yes, I could probably just warp to the next map - but then I'd lose all my current items...
- Grampa
https://www.neowin.net/forum/topic/245963-hl2-problem/#findComment-589062301
  The_Decryptor said:
It gets buggy if it relies on certain things, first time I went through there I did it quickly and it worked ok, second time I let a few rebels die, and he turned mute.
Same here most of the rebels died anyway because I was trying to be a john mcclane :laugh:
https://www.neowin.net/forum/topic/245963-hl2-problem/#findComment-589062926
  and1direct said:
Best reply ever :p
THERE was a glitch/problem in a warez release....I hope you have nothing to do with this.
That glitch was in the first HL2 release that got out from the Warez Scene by...was it Emporio?
anyway I dont think it had anything to do with this, it was some thing that you could fix quickly in the console If im not completely mistaken-
https://www.neowin.net/forum/topic/245963-hl2-problem/#findComment-589067110
