mcb Posted October 16, 2001 Share Posted October 16, 2001 when using ICQ plus, the More/Cancel/Send buttons get cut off. (see pic) I'm using the latest build of icq2000b, ICQ PowerCrack 4.65 to remove ads, and the latest version of ICQ Plus. I have friends who are running the same combination of programs, but to not have any problems. does anyone know how i can solve this problem, either by using reshack or something to shift the buttons up, or any other solution? I am also running XP Final, if that helps. Thanks Link to comment https://www.neowin.net/forum/topic/2549-icqplus-problem/ Share on other sites More sharing options...
0 Steven P. Administrators Posted October 16, 2001 Administrators Share Posted October 16, 2001 Thats not a ICQ Plus problem, thats a Windows Crappy Blinds problem Im afraid to say. The same happens to me without ICQPlus (i dont have it) when I installed Winblinds on XP Link to comment https://www.neowin.net/forum/topic/2549-icqplus-problem/#findComment-16638 Share on other sites More sharing options...
0 linsook Posted October 16, 2001 Share Posted October 16, 2001 is your crack.... go get another one. reinstall icq, and i'm sure that'll be fixed, then go find another crack to remove those ads. Link to comment https://www.neowin.net/forum/topic/2549-icqplus-problem/#findComment-16639 Share on other sites More sharing options...
mcb
Thanks
https://www.neowin.net/forum/topic/2549-icqplus-problem/Share on other sites
2 answers to this question
