Elliot B. Posted December 23, 2004 Share Posted December 23, 2004 I can't hear sound (Winamp, games etc.) unless I turn the speakers up full blast, and the volume control is full. Any other ideas? Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/ Share on other sites More sharing options...
null_ Posted December 23, 2004 Share Posted December 23, 2004 Make sure all the external connections are secure and reinstall your sound drivers. Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585151056 Share on other sites More sharing options...
Elliot B. Posted December 23, 2004 Author Share Posted December 23, 2004 iCeFuSiOn said: Make sure all the external connections are secure and reinstall your sound drivers. 585151056[/snapback] External connections are secure and I have reinstalled my sound card drivers. Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585151066 Share on other sites More sharing options...
dreamz Veteran Posted December 23, 2004 Veteran Share Posted December 23, 2004 check your additional sound properties. Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585151129 Share on other sites More sharing options...
Elliot B. Posted December 23, 2004 Author Share Posted December 23, 2004 dreamz said: check your additional sound properties. 585151129[/snapback] Here you go... Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585152409 Share on other sites More sharing options...
Elliot B. Posted December 23, 2004 Author Share Posted December 23, 2004 That is the weirdest thing... if I move the slider up and down (Master Volume) it has no effect on the volume but I noticed it sounded loud at certain bits. I moved the slider per pixel and now I have full sound unless I move it (look at the screenshot). Bizarre :| Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585152452 Share on other sites More sharing options...
forster Posted December 23, 2004 Share Posted December 23, 2004 Ive got this problem at the moment too, it used to be that I didnt need to turn my speakers anything past a couple of clicks, now they need to be two thirds of the way round :blink: No major upgrades to hardware / software recently, it's really beginning to bug me. Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585152460 Share on other sites More sharing options...
cyberfrem Posted December 23, 2004 Share Posted December 23, 2004 King Mustard said: I can't hear sound (Winamp, games etc.) unless I turn the speakers up full blast, and the volume control is full. Any other ideas? I've an idea - get your ears syringed! :D (sorry - I couldn't resist! ;) ) Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585152476 Share on other sites More sharing options...
Matrix XII Posted December 23, 2004 Share Posted December 23, 2004 that's very weird... when you move it to the bottom it works? Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585152562 Share on other sites More sharing options...
Panacik Posted December 23, 2004 Share Posted December 23, 2004 This can be a number of different things. I find personally this happens over time when the wires start to get old which connect your speakers to the machine. In this case it is best to buy new speakers. The other thing is that you need to try upgraded or downgraded sound software. Also playig with the options within control panel etc. With my sound card i had real bad problems even when i set everything in the control panel sound options i would not get full sound. I found out that there was some software i ahd to install on the machine which give you extra options on the sound which Windows does not give you. It was really fiddely but i got there in the end. Sorry i cant be much more help but i am sure you have a software problems there, which may be resolved by installing any extra software which came with the NVidia sound card. Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585153978 Share on other sites More sharing options...
gxken Posted January 20, 2005 Share Posted January 20, 2005 I am having the same exact problem. Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585324044 Share on other sites More sharing options...
wasabi Posted January 20, 2005 Share Posted January 20, 2005 theres an audio codec addon called Matrixmixer - which easily enhances the soundoutput to 500% more. problem is it can lead to sound distortion. http://matrix-mixer.sourceforge.net/ Videolan - enhances movies audio by 150% hope this helps. Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585325216 Share on other sites More sharing options...
insanekiwi Posted January 20, 2005 Share Posted January 20, 2005 shushu said: theres an audio codec addon called Matrixmixer - which easily enhances the soundoutputto 500% more. problem is it can lead to sound distortion. http://matrix-mixer.sourceforge.net/ Videolan - enhances movies audio by 150% hope this helps. 585325216[/snapback] thanks for matrixmixer. Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585325230 Share on other sites More sharing options...
saxondale. Posted January 20, 2005 Share Posted January 20, 2005 i guess you could say i have the same problem, my volume keeps changing by its self Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585325241 Share on other sites More sharing options...
gxken Posted January 21, 2005 Share Posted January 21, 2005 I used matrix mixer, and it raised the volume for all my video files pretty well. But when I play mp3s using foobar, the volume is not changed. Also my bass does not work unless I raise it way high. Link to comment https://www.neowin.net/forum/topic/260991-why-is-my-volume-so-quiet/#findComment-585329991 Share on other sites More sharing options...
