guru369 Posted January 23, 2005 Share Posted January 23, 2005 Hey All. I will try to explain it good: Somehow I manage to screw up my default action for double clicking a folder. I did it from the folder options-->filetypes. Now I can seem to restore it to open the folder. Does anybody knows how to restore it? Thanks in advance. You are my only hope before formatting.... Guru Link to comment https://www.neowin.net/forum/topic/275174-help-needed-with-double-click-default-action/ Share on other sites More sharing options...
acedriver Posted January 23, 2005 Share Posted January 23, 2005 find it here, most probably line 215 Link to comment https://www.neowin.net/forum/topic/275174-help-needed-with-double-click-default-action/#findComment-585340883 Share on other sites More sharing options...
guru369 Posted January 23, 2005 Author Share Posted January 23, 2005 find it here, most probably line 215 585340883[/snapback] Thanks, But this is how to set explorer as the default action. I need to modify the open. to open in the same window. I have accedently chnaged the action .... Guru Link to comment https://www.neowin.net/forum/topic/275174-help-needed-with-double-click-default-action/#findComment-585340960 Share on other sites More sharing options...
acedriver Posted January 23, 2005 Share Posted January 23, 2005 didn't the registry file in that page do that? Link to comment https://www.neowin.net/forum/topic/275174-help-needed-with-double-click-default-action/#findComment-585341021 Share on other sites More sharing options...
