Sound problems with Linux
I'm running Ubuntu, I just installed esound client and alsa-oss too, everything works fine 'cept for the recording, I think it's because I didn't set mic boost. But I can't set the mic boost!
Here's the output from amixer
Simple mixer control 'Master',0
  Capabilities: pvolume
  Playback channels: Front Left - Front Right
  Limits: Playback 0 - 31
  Front Left: Playback 10 [32%]
  Front Right: Playback 10 [32%]
Simple mixer control '3D Control - Switch',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'PCM',0
  Capabilities: pvolume pswitch pswitch-joined cswitch
  Capture channels: Front Left - Front Right
  Front Left: Playback 22 [71%] [on] Capture [off]
  Front Right: Playback 22 [71%] [on] Capture [off]
Simple mixer control 'Synth',0
Simple mixer control 'Line',0
  Capabilities: pvolume pswitch cswitch
  Front Left: Playback 27 [87%] [on] Capture [off]
  Front Right: Playback 27 [87%] [on] Capture [off]
Simple mixer control 'Line-In As Bass',0
  Mono: Playback [on]
Simple mixer control 'Line-In As Rear',0
  Mono: Playback [on]
Simple mixer control 'CD',0
Simple mixer control 'Mic',0
  Capabilities: pvolume pvolume-joined cvolume pswitch pswitch-joined cswitch cswitch-joined
  Capture channels: Mono
  Limits: Playback 0 - 31 Capture 0 - 7
  Mono: Playback 27 [87%] [on] Capture 4 [57%] [on]
Simple mixer control 'Mic As Center/LFE',0
  Mono: Playback [on]
Simple mixer control 'Mic Boost',0
  Mono: Playback [on]
Simple mixer control 'IEC958 5V',0
  Mono: Playback [on]
Simple mixer control 'IEC958 Copyright',0
  Mono: Playback [on]
Simple mixer control 'IEC958 In Monitor',0
  Mono: Playback [on]
Simple mixer control 'IEC958 In Phase Inverse',0
  Mono: Playback [on]
Simple mixer control 'IEC958 In Select',0
  Mono: Playback [on]
Simple mixer control 'IEC958 In Valid',0
  Mono: Playback [on]
Simple mixer control 'IEC958 Loop',0
  Mono: Playback [on]
Simple mixer control 'IEC958 Output',0
  Mono: Playback [on]
Simple mixer control 'PC Speaker',0
  Mono: Playback 2 [67%]
Simple mixer control 'Aux',0
  Limits: Playback 0 - 15
  Front Left: Playback 11 [73%] [on] Capture [off]
  Front Right: Playback 11 [73%] [on] Capture [off]
Simple mixer control 'Four Channel Mode',0
  Mono: Playback [on]
Help me plz! Iwant to use skype!
https://www.neowin.net/forum/topic/279775-sound-problems-with-linux/
