DannyGlass Posted March 27, 2005 Share Posted March 27, 2005 Well ive just been checking out the news at designtechnica.com and it is going on about the "Two Finnish overclocking gurus broke the 3dMark world record using a special liquid nitrogen cooling system and two XFX Nvidia cards in SLI-mode." So does this mean that liquid nitrogen cooling for graphics card is the way to go? -DannyGlass Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/ Share on other sites More sharing options...
AionXn_ Posted March 27, 2005 Share Posted March 27, 2005 i saw the video on this. i dont think you can use it because you need this big thing attached to the cpu. you cant close the case and he computer must lie on its side. i dont know, i havent researched about this enough to know the answer Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585679830 Share on other sites More sharing options...
+dave164 Subscriber¹ Posted March 27, 2005 Subscriber¹ Share Posted March 27, 2005 Yeh its a big massive things that sits on top of it, its very expensive + isn't liquid nitrogen illegal or something :blink: Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585679914 Share on other sites More sharing options...
Vice Posted March 27, 2005 Share Posted March 27, 2005 you could set this up in a sealed unit but its not a good idea to use it full stop. its expensive the hardware would not hold out very long and not worth it. use water cooling for day to day use liquid nitrogen is only good for breaking world records. Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585679941 Share on other sites More sharing options...
Spyker Posted March 27, 2005 Share Posted March 27, 2005 yeah, ,its possible and you can do it, its not as diffiuclt as you would imagine, it is still a bit fiddly and dangerous but its douable. Check here http://forums.extremeoverclocking.com/forumdisplay.php?f=184 Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585680066 Share on other sites More sharing options...
Circaflex Posted March 27, 2005 Share Posted March 27, 2005 also its used just for a few benchmark runs, not 24/7 and its more for your e-penis to be > theirs. If you want extreme cooling go lightspeed or machII, but watch your electric bill shoot up to hell. Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585680148 Share on other sites More sharing options...
SkaterAustin Posted March 27, 2005 Share Posted March 27, 2005 liquid nitrogen isn't illegal, its just that you dont want to come in touch with it unless u want severe frost bite lol and cooling a pc with it requires a holding tank, a tower big enough to handle the heat sinks, and a really really good overclocking and pc modding background. Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585680178 Share on other sites More sharing options...
Rudy Posted March 27, 2005 Share Posted March 27, 2005 too bad this cant be used for day to day use :p Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585680183 Share on other sites More sharing options...
Blimpo Posted March 27, 2005 Share Posted March 27, 2005 Wouldn't it be impossible? Doesn't liquid nitrogen run out after a certain amount of time? :huh: Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585680185 Share on other sites More sharing options...
SkaterAustin Posted March 27, 2005 Share Posted March 27, 2005 Blimpo said: Wouldn't it be impossible? Doesn't liquid nitrogen run out after a certain amount of time? :huh: 585680185[/snapback] well ya liquid nitrogen essientally turns into water after 1 use, so yes you would have to keep up the holding tanks :whistle: Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585680196 Share on other sites More sharing options...
stncttr908 Veteran Posted March 27, 2005 Veteran Share Posted March 27, 2005 That would be extremely expensive. It's just used for extreme overclocking tests and is not practical for an everyday computer. Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585680503 Share on other sites More sharing options...
Mx Posted March 27, 2005 Share Posted March 27, 2005 stncttr908 said: That would be extremely expensive. It's just used for extreme overclocking tests and is not practical for an everyday computer. 585680503[/snapback] Yup :yes: Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585680511 Share on other sites More sharing options...
Vidar Posted March 28, 2005 Share Posted March 28, 2005 Actually, Cryotech has been around for a very long time. I have messed with one and can personally attest, bad idea in hi-humidity areas. Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585682800 Share on other sites More sharing options...
Aeonandromere Posted March 28, 2005 Share Posted March 28, 2005 Quote Yeh its a big massive things that sits on top of it, its very expensive + isn't liquid nitrogen illegal or something :blink: No it aint illegal, actually its relatively cheap ****. Storing the stuff is the difficult part. Link to comment https://www.neowin.net/forum/topic/301519-liquid-nitrogen-cooling-system/#findComment-585682900 Share on other sites More sharing options...
