DeepBlade Posted May 19, 2005 Share Posted May 19, 2005 OK, last night, i remember seeing some automatic update thing that XP runs when it has a very important update and it forced my comp to reset while I was sleeping, this morning, I try to run MSN Messenger and it just doesn't work properly.. I don't know if that update was related to this or not, but when I try to start MSN Messenger 6.2, I only see 2 ppl online (not normal) and the tabs on the left don't load.. and I can't message people.. whenever I mouse over MSN, it gives me a busy icon or the array with busy icon thing... I tried downloading and installing 7.0 but it was the same problem.. so I uninstalled it, installed 6.2 again but I still have the same problem.. It's not like it's using 100% CPU either, it's just not responding... I tried web messenger and it works fine, so it must be something wrong on my side.. Oh, now I get some kind of pop up, but.. it's not 100% popping up, it stuck like this, indefinately... Link to comment https://www.neowin.net/forum/topic/322351-msn-messenger-problem/ Share on other sites More sharing options...
Joel Posted May 20, 2005 Share Posted May 20, 2005 Wonder if it has anything to do with your Hentai image you hacked in. :p Link to comment https://www.neowin.net/forum/topic/322351-msn-messenger-problem/#findComment-585947654 Share on other sites More sharing options...
temple_treefrog Posted May 20, 2005 Share Posted May 20, 2005 Did you try the repair function from Windows Installer? If that doesn't work I suggest you delete the application data folder for MSN Messenger (you'll loose your display pic's when you do this), the folder location should be C:\Documents and Settings\{your username}\Application Data\Microsoft\MSN Messenger Joel said: Wonder if it has anything to do with your Hentai image you hacked in. :p 585947654[/snapback] lol Link to comment https://www.neowin.net/forum/topic/322351-msn-messenger-problem/#findComment-585948291 Share on other sites More sharing options...
McLaren_F1 Posted May 20, 2005 Share Posted May 20, 2005 sorry to go off topic. but how to do add pics like that on the main background? Link to comment https://www.neowin.net/forum/topic/322351-msn-messenger-problem/#findComment-585948489 Share on other sites More sharing options...
DeepBlade Posted May 21, 2005 Author Share Posted May 21, 2005 nope, i've had that background for the longest time and it worked fine oh it's quite easy, u just need a pic, save it as gif in a particular format, and put it in the directory.. here's a more detailed tutorial http://www.winguides.com/registry/display.php/873/ Link to comment https://www.neowin.net/forum/topic/322351-msn-messenger-problem/#findComment-585951501 Share on other sites More sharing options...
DeepBlade Posted May 21, 2005 Author Share Posted May 21, 2005 ok the repair thing at windows installer worked! thx a lot!!! i don't know why i didn't see this b4.. a mod can close this topic now if they want.. Link to comment https://www.neowin.net/forum/topic/322351-msn-messenger-problem/#findComment-585951527 Share on other sites More sharing options...
McLaren_F1 Posted May 22, 2005 Share Posted May 22, 2005 DeepBlade said: nope, i've had that background for the longest time and it worked fineoh it's quite easy, u just need a pic, save it as gif in a particular format, and put it in the directory.. here's a more detailed tutorial http://www.winguides.com/registry/display.php/873/ 585951501[/snapback] Thanks :) Link to comment https://www.neowin.net/forum/topic/322351-msn-messenger-problem/#findComment-585954305 Share on other sites More sharing options...
temple_treefrog Posted May 23, 2005 Share Posted May 23, 2005 DeepBlade said: ok the repair thing at windows installer worked! thx a lot!!!i don't know why i didn't see this b4.. a mod can close this topic now if they want.. 585951527[/snapback] ;) Link to comment https://www.neowin.net/forum/topic/322351-msn-messenger-problem/#findComment-585958302 Share on other sites More sharing options...
