Problem with patch of GTA San Andreas
I have download the patch of San Andreas and when I tried to install I receive this message:Old file not found. However, a file og the same name was found. No update done since file contents do not match
Wha I can do? :(
LOL are you talking about the HC mod? anyway if you have a new san andreas copy its been removed from the code, so you cant get it ;)
586405184[/snapback]
He's talking about the v1.01 update...
Anyways, it means you have the wrong version of the patch. Try downloading the Euorpean one.
did you install any mod on San Andreas? it says you need to have an unmodded game installed. Try installing the game again and then apply the patch
Anyone who have the uncrack gta_sa.exe?
586405262[/snapback]
Don't ask for that stuff here, if you have a legit copy, re-install the game and your problems should be fixed. If this is not the case, your at the wrong website and just asking for trouble.
