Wannes Posted January 12, 2006 Share Posted January 12, 2006 Upon installing Visual Studio, legal, I get the following error: (See attachment) Does anyone know a way to get those files? They are not on my CD's, I downloaded it via MSDNAA. Link to comment https://www.neowin.net/forum/topic/419852-visual-studio-problem/ Share on other sites More sharing options...
0 spartyjohnson Posted January 12, 2006 Share Posted January 12, 2006 Error? You put in the disk. It comes with that package of VS.net that is on MSDNAA. I got mine there. Link to comment https://www.neowin.net/forum/topic/419852-visual-studio-problem/#findComment-587055845 Share on other sites More sharing options...
0 +John Teacake MVC Posted January 12, 2006 MVC Share Posted January 12, 2006 My mate had this same problem when he was using his copy from MSDNAA Link to comment https://www.neowin.net/forum/topic/419852-visual-studio-problem/#findComment-587055856 Share on other sites More sharing options...
0 Wannes Posted January 12, 2006 Author Share Posted January 12, 2006 Did your mate find a solution? Link to comment https://www.neowin.net/forum/topic/419852-visual-studio-problem/#findComment-587055860 Share on other sites More sharing options...
0 Vykranth Posted January 12, 2006 Share Posted January 12, 2006 How many CD do you have on MSDNDNA? VS 2003 Pro comes into 6 disks: 1 disk for Prerequisistes, 2 disks for VS 2003, 3 CDs for MSDN Library. Did you download everything? Link to comment https://www.neowin.net/forum/topic/419852-visual-studio-problem/#findComment-587055866 Share on other sites More sharing options...
0 spartyjohnson Posted January 12, 2006 Share Posted January 12, 2006 Go into MSDNAA and look for Prereq. CD ISO. It is in there. See attachment. Link to comment https://www.neowin.net/forum/topic/419852-visual-studio-problem/#findComment-587055895 Share on other sites More sharing options...
0 TheWahbinator Posted January 12, 2006 Share Posted January 12, 2006 Make sure the prequisites disc is labeled "VSWCUD1" Link to comment https://www.neowin.net/forum/topic/419852-visual-studio-problem/#findComment-587055899 Share on other sites More sharing options...
0 Wannes Posted January 12, 2006 Author Share Posted January 12, 2006 Vykranth said: How many CD do you have on MSDNDNA? VS 2003 Pro comes into 6 disks: 1 disk for Prerequisistes, 2 disks for VS 2003, 3 CDs for MSDN Library. Did you download everything? I was told I didn't need the libraries? I'll down those prerequisistes. Link to comment https://www.neowin.net/forum/topic/419852-visual-studio-problem/#findComment-587055991 Share on other sites More sharing options...
0 Wannes Posted January 12, 2006 Author Share Posted January 12, 2006 Yep, I had forgotten to download a CD. :blush: Thank you! Link to comment https://www.neowin.net/forum/topic/419852-visual-studio-problem/#findComment-587056114 Share on other sites More sharing options...
Wannes
https://www.neowin.net/forum/topic/419852-visual-studio-problem/Share on other sites
8 answers to this question
