Business Posted January 23, 2006 Share Posted January 23, 2006 Ok heres the problem (one of many anyway) my mic has a low volume and even though I have it set to max on the actually control panel options it's not high enough >.< any ideas? Link to comment https://www.neowin.net/forum/topic/424180-going-higher-than-max-volume-for-mic-in-windows/ Share on other sites More sharing options...
AMDMEFX-55 Posted January 23, 2006 Share Posted January 23, 2006 have you tried the mic boost in windows? Link to comment https://www.neowin.net/forum/topic/424180-going-higher-than-max-volume-for-mic-in-windows/#findComment-587103567 Share on other sites More sharing options...
Rob Veteran Posted January 23, 2006 Veteran Share Posted January 23, 2006 It depends on what you're using it for. I'm assuming that, as the above poster mentions, you've got microphone boost switched on. If you want it for Skype or some other real-time chatting application I know of no way to boost it other than buying a preamp or, cheaper, just buying a better microphone. If you're recording with it, then you can normalise the audio to peak level and artificially boost it after recording. Link to comment https://www.neowin.net/forum/topic/424180-going-higher-than-max-volume-for-mic-in-windows/#findComment-587103569 Share on other sites More sharing options...
Business Posted January 23, 2006 Author Share Posted January 23, 2006 Ok I DID NOT see that boost feature, I'll check it when i get home. Link to comment https://www.neowin.net/forum/topic/424180-going-higher-than-max-volume-for-mic-in-windows/#findComment-587103577 Share on other sites More sharing options...
AMDMEFX-55 Posted January 23, 2006 Share Posted January 23, 2006 You might need to turn on advance in the audio control panel. Link to comment https://www.neowin.net/forum/topic/424180-going-higher-than-max-volume-for-mic-in-windows/#findComment-587103584 Share on other sites More sharing options...
Business Posted January 23, 2006 Author Share Posted January 23, 2006 Thanks again I'll got scope it out once I get home ^.^ Link to comment https://www.neowin.net/forum/topic/424180-going-higher-than-max-volume-for-mic-in-windows/#findComment-587103592 Share on other sites More sharing options...
