  RYFX said:
Is their anything more system light than firefox or opera?
errm i dunno, ive not really looked into resource usage for each browser.
best advice i can give is to find a browser you like the features of and then give it a try and see what the resource usage ends up being.
EDIT:
That probably wasn't all that usefull really was it, sorry!
  RebelFX said:
Mozilla Suite. My brother is still playing with a crappy PIII 700 Mhz and 256 MB RAM and Mozilla Suite is way faster than other browsers since it's not a resource hog.
Otherwise, check out Maxthon.
lol firefox was created to be a slimmed down version of the mozilla suite.
anyway at 733Mhz, you shouldn't have any problems with using any browser, if things seem slow it could be spyware/adware, or your internet connection.
I have an old computer in the other room that is a 334mhz and it runs normal firefox with some plugins fine.
As a matter of fact, I installed Mozilla Suite in that PC switching back from FF. He didn't use any extension or theme with FF and yet surfing was sometimes slow as hell. It took years to load some websites. Now all the problems are gone. ;)
BTW, I forgot to mention that the PC has Win ME installed.
  icecaveman said:
Opera or IE, it's crazy to run Firefox with all it's memory leaks on so weak system, Firefox is the heaviest browser avaialbe, even the bloated version of netscape is lighter than that ill opmtimized piece current of Firefox 0.1.x BETA
Slightly incorrect Firefox is generally fine, it is the extensions that are the problem and if you disable the page cache thing (the thing that remembers the pages hen you go back) it is very light weight.
Anyway user what you want, you should be fine with anything.
lol well there's your problem. :rofl:
I would most definitely say Opera. Opera is known to be blazingly responsive on any system compared to any of it's comptetions and will most definitely run fastest especially on older systems. And definitely NOT firefox, it's going to be way too slow compared to Opera on a system like that. With Opera you won't feel you're using a slow system.
