bmdixon Posted February 16, 2006 Share Posted February 16, 2006 When i open firefox it looks like this!: Does anybody know why it would do this? Thanks :) Link to comment https://www.neowin.net/forum/topic/433164-firefox-problem/ Share on other sites More sharing options...
Kraftman Posted February 16, 2006 Share Posted February 16, 2006 Kind of, I hade the same issue with IEView... I think. Try disabling IEView and resarting Firefox. Link to comment https://www.neowin.net/forum/topic/433164-firefox-problem/#findComment-587203774 Share on other sites More sharing options...
Salgoth Posted February 16, 2006 Share Posted February 16, 2006 Does it do the same thing (not being maximized) when you use the standard/default theme? Link to comment https://www.neowin.net/forum/topic/433164-firefox-problem/#findComment-587203783 Share on other sites More sharing options...
bmdixon Posted February 17, 2006 Author Share Posted February 17, 2006 it appears the problem is due to the "easy gestures" extension. Is this likely to be a problem with the extension itself or just me? Thanks for your help btw :) Link to comment https://www.neowin.net/forum/topic/433164-firefox-problem/#findComment-587208039 Share on other sites More sharing options...
Salgoth Posted February 17, 2006 Share Posted February 17, 2006 http://easygestures.mozdev.org/ That's the site for easyGestures. I didn't se anybody else having your problem so it might be a conflict between easy Gestures and another extension. I had a problem between Magpie 3.2.5 and Menu Editor 1.2 when using the CTRL+Shift+S combination so it is possible that two extensions might not get along. Link to comment https://www.neowin.net/forum/topic/433164-firefox-problem/#findComment-587208424 Share on other sites More sharing options...
Ashiaveli Posted February 18, 2006 Share Posted February 18, 2006 just disable your extensions one by one till it's fixed. Link to comment https://www.neowin.net/forum/topic/433164-firefox-problem/#findComment-587212172 Share on other sites More sharing options...
+M2Ys4U Subscriber¹ Posted February 18, 2006 Subscriber¹ Share Posted February 18, 2006 That happened to me, couldn't remember what the culprit was. I nuked both my profile and reinstalled fx; was on a flash drive for college so I didn't loose anything. Link to comment https://www.neowin.net/forum/topic/433164-firefox-problem/#findComment-587212797 Share on other sites More sharing options...
eisneun Posted February 18, 2006 Share Posted February 18, 2006 see: http://kb.mozillazine.org/Gray_bar_below_status_bar Link to comment https://www.neowin.net/forum/topic/433164-firefox-problem/#findComment-587213625 Share on other sites More sharing options...
gur713 Posted February 19, 2006 Share Posted February 19, 2006 its a locale problem with one of the extensions disable the extension that you isntalled before that started to happen Link to comment https://www.neowin.net/forum/topic/433164-firefox-problem/#findComment-587215121 Share on other sites More sharing options...
bmdixon Posted February 20, 2006 Author Share Posted February 20, 2006 I've got rid of a few extensions that i don't really need and so far it seems to be sorted :) Thanks for your help :) Link to comment https://www.neowin.net/forum/topic/433164-firefox-problem/#findComment-587219453 Share on other sites More sharing options...
