Elliot B. Posted March 22, 2006 Share Posted March 22, 2006 How do I use the Xbox 360 pad in Silent Hill? I can't see an option anywhere. EDIT: Found it... (4)--Enabling Use of a Gamepad--It's not possible to configure a gamepad through the game launcher, due to the unknown coding of the emulator's gamepad features. However, you can still use one if you configure it using the emulator itself (ePSXe.exe). First, make sure you enable the use of external control configuring. To do this, run the game launcher, go to "Controls", then select the option labeled "Use External Configuration". What this does is disables the integrated control configuration system, and allows another program (such as the emulator) to configure the controls instead. Now that an outside program can be used, run the emulator. You can do this by opening the "ePSXe.exe" file, which is located in your Silent Hill directory. Then click "Config", and then go to "Game Pad", and click "Pad 1". This is where you will map the controls. Since this is a Playstation emulator, it shows a Playstation gamepad. Here's what each button on the gamepad does: Up = Walk Forward Down = Walk Backward Left = Turn Left Right = Turn Right Cross (X) = Action \ Fire Weapon \ Use Square = Run Triangle = View Map \ Exit Menu Screens Circle = Turn On or Off Flashlight \ Exit Menu Screens L1 = Look Around L2 = Sidestep Left R1 = Raise Weapon R2 = Sidestep Right Start = Pause Game \ Skip Movie Scenes Select = Access Inventory Now you can configure the use of a gamepad. Link to comment Share on other sites More sharing options...
