Sandy Posted March 30, 2006 Share Posted March 30, 2006 Well, I need to get some CD's, quick replys please, shop closes soon i gotta run down there LOL Whats difference between CD-R and CD+R? :wacko: and is it worth getting CDRW - or + if im holding temporary data or is it cheaper to get CDR's - or +? Thanks in Advance (Y) Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/ Share on other sites More sharing options...
Kasandoro Posted March 30, 2006 Share Posted March 30, 2006 Didn't know there was such a thing as CD+R's...I've heard of (and use) DVD+R, DVD-R, DVD+RW and DVD-RW though... Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/#findComment-587366689 Share on other sites More sharing options...
temple_treefrog Posted March 30, 2006 Share Posted March 30, 2006 Sandy said: Well, I need to get some CD's, quick replys please, shop closes soon i gotta run down there LOL Whats difference between CD-R and CD+R? :wacko: and is it worth getting CDRW - or + if im holding temporary data or is it cheaper to get CDR's - or +? Thanks in Advance (Y) I'm quite sure CD+R or CD+RW does not exist. The main difference between DVD-R/-RW and DVD+R/+RW is that 'plus' discs support a burning method called packet writing. While 'minus' discs don't support packet writing, they have better compatibility with older DVD-ROM drives and DVD players. Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/#findComment-587367056 Share on other sites More sharing options...
KayMan2K Posted March 30, 2006 Share Posted March 30, 2006 I have NEVER heard of a media called CD+R or CD+RW. I understand there to only be one format for recordable CDs called CD-R (which stands for CD-Recordable). There are two flavors of DVD (+ and -), the major different being how data is written with respect to the reference spirals (or so I think). Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/#findComment-587367067 Share on other sites More sharing options...
BryanChung Posted March 31, 2006 Share Posted March 31, 2006 So actually both + - has not much of a difference eh ? Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/#findComment-587369242 Share on other sites More sharing options...
Sn4k36 Posted March 31, 2006 Share Posted March 31, 2006 there's only cd-r for your cds but for dvd's there dvd+r's and dvd-r's (also +/- rw) but if ur going for dvd's also go for dvd+r's.... Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/#findComment-587369251 Share on other sites More sharing options...
KC Posted March 31, 2006 Share Posted March 31, 2006 Yup never heard of a CD+R. As far as RW vs R goes. I hardly ever use RW because CD-Rs are so cheap. Every once in a great moon I will use a RW for testing a iso burn or something but thats about it. Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/#findComment-587369261 Share on other sites More sharing options...
EddieF Posted March 31, 2006 Share Posted March 31, 2006 CD-RWs would be nice if they burned as fast as CD-Rs. But they burn much slower so I prefer to use CD-Rs. Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/#findComment-587369320 Share on other sites More sharing options...
Vice Posted March 31, 2006 Share Posted March 31, 2006 EddieF said: CD-RWs would be nice if they burned as fast as CD-Rs. But they burn much slower so I prefer to use CD-Rs. And when you consider how cheap CD-R's are now, its like ?5 for 200 at some online shops.:|| That's 140GB of portable storage for ?5.. (if each disc holds 700MB each x200 working discs) Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/#findComment-587369327 Share on other sites More sharing options...
TaRaKa Posted March 31, 2006 Share Posted March 31, 2006 CD+R's dont exist Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/#findComment-587369489 Share on other sites More sharing options...
styn...big wlmesser P Posted March 31, 2006 Share Posted March 31, 2006 About those DVD's, the DVD+RW are mainly better than DVD-RW? Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/#findComment-587369734 Share on other sites More sharing options...
DrunkenMaster Posted March 31, 2006 Share Posted March 31, 2006 styn...big wlmesser P said: About those DVD's, the DVD+RW are mainly better than DVD-RW? For DVD's I'd get anything +R if your burner supports it. +R discs have extra error correction codes making it better to store Data. If you're using on your computer. If its for a DVD player check and make sure its compatible. Link to comment https://www.neowin.net/forum/topic/447878-difference-between-cd-r-and-cdr/#findComment-587369888 Share on other sites More sharing options...
