r3volution Posted April 15, 2006 Share Posted April 15, 2006 (edited) Client: uTorrent 1.5 Tracker URL: ///a tracker that is reliable/// Tracker Status: offline (timed out) UPLOADING...not downloading i have no idea y the status is always at offline(timed out) when i check their site (ThePirateBay.org), it says my file has 0 seeds and 0 peers i know that it isn't the tracker's problem cuz other files from other people do not have this problem i think i also had a similar problem with Azureus when i was uploading so i dun think its uTorrent's probelm either -thanks Edited April 17, 2006 by sd.caboose Link to comment https://www.neowin.net/forum/topic/452567-utorrent-tracker-problem/ Share on other sites More sharing options...
0 Yochanan Posted April 15, 2006 Share Posted April 15, 2006 It's a problem with the tracker, not ?Torrent. Sometimes when there's heavy load on a tracker, it will report it's offline because the request from your client is timing out. You're connected to peers through DHT/Peer Exchange, or you got some seeds/peers from the tracker when/if you were connected earlier. Make sure you have both Enable DHT and Peer Exchange checked when you're using a public tracker. Link to comment https://www.neowin.net/forum/topic/452567-utorrent-tracker-problem/#findComment-587415833 Share on other sites More sharing options...
0 Slimy Posted April 15, 2006 Share Posted April 15, 2006 Add some more trackers ;) http://thebeehive.info/?p=tlist Link to comment https://www.neowin.net/forum/topic/452567-utorrent-tracker-problem/#findComment-587415848 Share on other sites More sharing options...
0 Tristan Posted April 15, 2006 Share Posted April 15, 2006 slimy said: Add some more trackers ;) if you dont want to get warned you should remove this link, the other day I got warned just for helping someone make backups of their dvd Link to comment https://www.neowin.net/forum/topic/452567-utorrent-tracker-problem/#findComment-587415868 Share on other sites More sharing options...
0 Yochanan Posted April 15, 2006 Share Posted April 15, 2006 Tristan said: if you dont want to get warned you should remove this link, the other day I got warned just for helping someone make backups of their dvd Really? Then be careful talking about Maximum PC magaizine, then. The April 2006 issue tells you how to copy/convert DVD's, copy-protected CD's and downloaded music. Link to comment https://www.neowin.net/forum/topic/452567-utorrent-tracker-problem/#findComment-587415907 Share on other sites More sharing options...
0 Tristan Posted April 15, 2006 Share Posted April 15, 2006 this is what the mod said Quote Tristan,I have raised your warning level for posting links to circumvent the DVD Copy Protection system. Making backup copies or not, this type of discussion is not allowed on Neowin. Neowin Rules said: 2. No Warez (links) & Cracks.Help, requests or posts that discuss circumvention. This includes linking to illegally obtained software, movies & music files - posting about it, and suggesting to get it. I suggest you read over the Neowin Community Rules before posting again. Thanks, Frank Link to comment https://www.neowin.net/forum/topic/452567-utorrent-tracker-problem/#findComment-587415920 Share on other sites More sharing options...
0 r3volution Posted April 15, 2006 Author Share Posted April 15, 2006 thanks guys..... slimy.....its me....mike....... Yochanan said: It's a problem with the tracker, not ?Torrent. Sometimes when there's heavy load on a tracker, it will report it's offline because the request from your client is timing out. You're connected to peers through DHT/Peer Exchange, or you got some seeds/peers from the tracker when/if you were connected earlier. Make sure you have both Enable DHT and Peer Exchange checked when you're using a public tracker. btw..... uTorrent doens't seem to let me use DHT and peer exchange it says DHT status: not allowed although in preferences i did enable it Link to comment https://www.neowin.net/forum/topic/452567-utorrent-tracker-problem/#findComment-587415971 Share on other sites More sharing options...
0 Slimy Posted April 15, 2006 Share Posted April 15, 2006 DHT is not allowed on private trackers, private torrents. It will turn on if you are downloading a public torrent. However, I have no idea why this error would occur for the piratebay, unless you/someone set the torrent to be private. Link to comment https://www.neowin.net/forum/topic/452567-utorrent-tracker-problem/#findComment-587415996 Share on other sites More sharing options...
0 r3volution Posted April 15, 2006 Author Share Posted April 15, 2006 ohhh....that explains a lot.... slimy...piratebay is private thanks Link to comment https://www.neowin.net/forum/topic/452567-utorrent-tracker-problem/#findComment-587416022 Share on other sites More sharing options...
r3volution
-thanks
Edited by sd.cabooseLink to comment
https://www.neowin.net/forum/topic/452567-utorrent-tracker-problem/Share on other sites
8 answers to this question
