Randolph Posted July 5, 2006 Share Posted July 5, 2006 I recently just obtained a 6GB Creative Zen Micro from a friend and I am having trouble upgrading the firmware. The firmware currently on it is "2.11.02" and the version I am trying to upgrade it to is "2.21.02" (Creative Zen Micro PlaysForSure Firmware update 2.21.02). I am presented with the following screen attached to this post. Note: I tryed unplugging it and replugging it back in with this window up and no go. :( Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/ Share on other sites More sharing options...
Spyder Veteran Posted July 5, 2006 Veteran Share Posted July 5, 2006 see if this helps you? http://dmzweb4.europe.creative.com/SRVS/CG...Case=obj(10053) I also found this in the firmware notes: Quote If a dialog box appears, telling you that an application is interfering with the update process, do the following:Launch Creative MediaSource Player/Organizer. Click Tools -> Settings. Click the Detector tab. In the Device(s) to Detect window, make sure that the Enable Detector checkbox is not selected. Restart your computer. Install the firmware update again. and Quote Requirements: Microsoft? Windows? XP with Service Pack 1 or 2, or Windows XP Professional x64 Windows Media Player 10 installed on your computer Available USB port (version 1.1 or higherFor non-PlaysForSure players only: Creative Zen Micro drivers, available from the Installation CD or the Internetb> Creative Zen Micro player I bolded the 1 line above. I don't know if your player is currently non-playsforsure but if so, maybe you need the driver installed? Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587672644 Share on other sites More sharing options...
Guest sendmarksmail Posted July 5, 2006 Share Posted July 5, 2006 Before you upgrade your firmware, try installing the drivers for the Zen Micro. After that disconnect and reconnect it. Then try upgrading the firmware again. I have a Zen Micro myself because I feel it's more functional than the iPod. I'll be getting the Zen Video soon. Enjoy your Zen Micro. Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587672767 Share on other sites More sharing options...
SoCalledChaos Posted July 5, 2006 Share Posted July 5, 2006 its true, my zen micro just doesnt work anymore.. and i only had it for 3 months.. and it just will not turn on no matter what..and it stopped working with my computer, and would not be recognized Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587672806 Share on other sites More sharing options...
Randolph Posted July 5, 2006 Author Share Posted July 5, 2006 Spyder: I tryed all that. Doesn't work. SoCalledChaos: Thank you for your wise comment. :rolleyes: sendmarksmail: Doesn't work. It says in the notes that even if it isnt a PlayForSure firmware, it should still upgrade over it. I can't seem to figure out whats going on. :/ Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587672809 Share on other sites More sharing options...
Guest sendmarksmail Posted July 5, 2006 Share Posted July 5, 2006 SoCalledChaos said: its true, my zen micro just doesnt work anymore.. and i only had it for 3 months.. and it just will not turn on no matter what..and it stopped working with my computer, and would not be recognized You could contact Creative and tell them that you need a replacement. I belive they have a 1 year warranty on that. First ask them nicely if they can send you a replacement once your ship it because you need it right away for a trip in the next few weeks. If not then ask them if you can send it in anywa. Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587672824 Share on other sites More sharing options...
3284lmm Posted July 5, 2006 Share Posted July 5, 2006 SoCalledchaos, you're joking, right? The zen micro is one of the most durable, ergonomic players out there. I still highly recommend it, and sometimes prefer it over my zen vision:m. Anyways, Tem, are what firmware version is your micro using, and what operating system are you using on your computer. If the firmware version starts with a 1 then you can using it on any service pack of windows xp or windows 2000. Likewise, if the firmware version on your micro starts with a 2, then you can only use it with Windows XP sp1 or2. If you are using an older operating system (windows 2000) then you will have to find a computer with XP sp1 or2 and switch the firmware version to the 1.11.01 firmware (non-mtp firmware). If you have windows xp sp2 with the MTP firmware on it then try uninstalling and reinstalling thew drivers. If this doesn't work, then you need to go into recovery mode on your player and reformat the drive. Socalledchaos, even if you charge it, it won't turn on? Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587672872 Share on other sites More sharing options...
Randolph Posted July 5, 2006 Author Share Posted July 5, 2006 3284lmm said: SoCalledchaos, you're joking, right? The zen micro is one of the most durable, ergonomic players out there. I still highly recommend it, and sometimes prefer it over my zen vision:m. Anyways, Tem, are what firmware version is your micro using, and what operating system are you using on your computer. If the firmware version starts with a 1 then you can using it on any service pack of windows xp or windows 2000. Likewise, if the firmware version on your micro starts with a 2, then you can only use it with Windows XP sp1 or2. If you are using an older operating system (windows 2000) then you will have to find a computer with XP sp1 or2 and switch the firmware version to the 1.11.01 firmware (non-mtp firmware). If you have windows xp sp2 with the MTP firmware on it then try uninstalling and reinstalling thew drivers. If this doesn't work, then you need to go into recovery mode on your player and reformat the drive. Socalledchaos, even if you charge it, it won't turn on? If you read the first post you would see it clearly says "2.11.02" as the firmware version. I am running Windows XP Home Edition SP2 w/ all updates+drivers. I tried unistalling and reinstalling the drivers. How do I go into recovery mode and reformat? Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587672895 Share on other sites More sharing options...
3284lmm Posted July 5, 2006 Share Posted July 5, 2006 Please don't get an attitude, I am trying to help. To acess recovery mode, take the battery out of the player and hold the power/hold switch all the way to the left. While holding the switch, place the battery into back into the player. The player will then boot into the recovery mode. Clean up and reformat the drive, then try connecting the player to your computer. Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587672923 Share on other sites More sharing options...
Randolph Posted July 5, 2006 Author Share Posted July 5, 2006 3284lmm said: Please don't get an attitude, I am trying to help. To acess recovery mode, take the battery out of the player and hold the power/hold switch all the way to the left. While holding the switch, place the battery into back into the player. The player will then boot into the recovery mode. Clean up and reformat the drive, then try connecting the player to your computer. I wasn't giving you a attitude. It's still giving me the "Your player is not connected, please connect your player." message. I "cleaned up" and "reformatted". I plugged it back it and I hear the windows device connect noise. I goto the firmware updater and it gives me that message listed above. :( Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587672941 Share on other sites More sharing options...
3284lmm Posted July 5, 2006 Share Posted July 5, 2006 Ok, do you have windows media player 10 or 11 installed? If you do, go to device manager (control panel -> system -> hardware -> device manager -> mtp devices -> open up mtp devices and look for the micro, click right on the micro and uninstall it. Unplug your micro and plug it back in. The computer should detect the micro and reinstall the drivers for it. Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587672971 Share on other sites More sharing options...
Randolph Posted July 5, 2006 Author Share Posted July 5, 2006 Ok this is what I see. And btw I appreciate you trying to help me. I unistalled "Creative Zen Micro". Unplugged it. Replugged it back in. Went through the Found New Hardware wizard. Still no go. Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587672981 Share on other sites More sharing options...
3284lmm Posted July 5, 2006 Share Posted July 5, 2006 No problem, is windows media player or media explorer detecting the micro? It looks as if you are using WMP11, try reverting back to WMP10, there have been known connectivity problems with WMP11. Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587673004 Share on other sites More sharing options...
Randolph Posted July 5, 2006 Author Share Posted July 5, 2006 (edited) 3284lmm said: No problem, is windows media player or media explorer detecting the micro? It looks as if you are using WMP11, try reverting back to WMP10, there have been known connectivity problems with WMP11. WMP11 detects just fine. Do you still want me to revert back to WMP 10? edit: Unistalled WMP 11, reverted back to 10. I did something in the recovery console and now I get a error "Firmware Problem" lol. :huh: Do you have a "installation cd" or something that might work? Then I can try the firmware upgrade? Edited July 5, 2006 by Tem Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587673028 Share on other sites More sharing options...
3284lmm Posted July 5, 2006 Share Posted July 5, 2006 Yes, i just tried a firmware upgrade on my micro and got the same error as you did. I too have windows media player 11 installed. uninstall it and you should be trouble free. Feel free to reinstall WMP11 after you complete the firmware upgrade though. Now that I think about it, I had the same problem with my Vision:m once, I couldn't get the firmware upgrade program to work on my desktop. When i tried updating with my laptop (WMP10) everything worked fine. Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587673149 Share on other sites More sharing options...
Randolph Posted July 5, 2006 Author Share Posted July 5, 2006 (edited) 3284lmm said: Yes, i just tried it on my micro and got the same error as to. I too have windows media player 11 installed. uninstall it and you should be trouble free. Feel free to reinstall WMP11 after you complete the firmware upgrade though. I don't seem to understand what your talking about? edit: This didn't solve anything. And now I am firmwareless. edit 2: I am so dumb lol. Edited July 5, 2006 by Tem Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587673158 Share on other sites More sharing options...
3284lmm Posted July 5, 2006 Share Posted July 5, 2006 OK, I tried to get the firmware program to detect my micro, like you I could not get it to detect my player. This means that windows media player 11 is in fact conflicting with the firmware update program. Did you uninstall the windows media player 11 and revert back to version 10? Also, I don't recall telling you to delete your firmware. If you do not have firmware on your player, simply go into recovery mode and attempt to load it from there. Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587673188 Share on other sites More sharing options...
Randolph Posted July 5, 2006 Author Share Posted July 5, 2006 3284lmm said: OK, I tried to get the firmware program to detect my micro, like you I could not get it to detect my player. This means that windows media player 11 is in fact conflicting with the firmware update program. Did you uninstall the windows media player 11 and revert back to version 10? Also, I don't recall telling you to delete your firmware. If you do not have firmware on your player, simply go into recovery mode and attempt to load it from there. I reverted back to 10 because I didn't like 11 anyways. How do I load my firmware from Recovery Mode? Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587673196 Share on other sites More sharing options...
3284lmm Posted July 5, 2006 Share Posted July 5, 2006 To acess recovery mode, take the battery out of the player and hold the power/hold switch all the way to the left. While holding the switch, place the battery into back into the player. The player will then boot into the recovery mode. There should be an option to reload firmware in there. Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587673212 Share on other sites More sharing options...
Randolph Posted July 5, 2006 Author Share Posted July 5, 2006 3284lmm said: To acess recovery mode, take the battery out of the player and hold the power/hold switch all the way to the left. While holding the switch, place the battery into back into the player. The player will then boot into the recovery mode. There should be an option to reload firmware in there. I know how to get in Recovery Mode. Ty though. "Firmware will be erased. Reload via USB"? Then it just closes out after I select "yes". :( Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587673226 Share on other sites More sharing options...
Randolph Posted July 6, 2006 Author Share Posted July 6, 2006 Anyone got any idea what I can do? Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587673843 Share on other sites More sharing options...
Randolph Posted July 6, 2006 Author Share Posted July 6, 2006 Ok sorry for triple posting. I am currently at my girlfriends house. I plugged in the Zen into her computer and the firmware upgrade went through. Shes running Windows XP Professional with no Service Pack. What I did was install the Zen Micro Windows drivers. Then I plugged it into a USB 1.1 port. And it got detected. I loaded the firmware updater and it updated it! Now I just wonder why my....NEWER computer can't do this? :huh: :wacko: Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587676571 Share on other sites More sharing options...
3284lmm Posted July 7, 2006 Share Posted July 7, 2006 Good to hear, sorry I couldn't remedy your problem. Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587676878 Share on other sites More sharing options...
Randolph Posted July 7, 2006 Author Share Posted July 7, 2006 3284lmm said: Good to hear, sorry I couldn't remedy your problem. Now I have another problem. I am able to sync with WMP 10. But when I still load the firmware update, it says please connect it......STILL! This probably isn't a huge problem right now but when a new firmware comes out and I need to update, then it will be. :no: Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587677132 Share on other sites More sharing options...
quick Posted July 7, 2006 Share Posted July 7, 2006 Probably unrelated, but for what its worth... Had the same problem with my Zen Vision:M couldn't get the firmware updater to connect to my device. Solution was in media player to set the name of the player to match the exact name of the player ie. "Creative Zen Vision:M" Once i did that it worked perfectly... this was possibly only windows media player 11 that caused this problem. Link to comment https://www.neowin.net/forum/topic/476158-zen-micro-firmware-problem/#findComment-587677144 Share on other sites More sharing options...
