cheeseman557 Posted August 22, 2006 Share Posted August 22, 2006 I have a Dell E1505 laptop and I have no idea what motherboard I have. My dell laptop is not listed under any of the options in motherboard monitor. Is there any way I can use Motherboard Monitor? Thanks. Link to comment https://www.neowin.net/forum/topic/488794-motherboard-monitor/ Share on other sites More sharing options...
0 Echilon Posted August 22, 2006 Share Posted August 22, 2006 Try CPU-Z to find out what model your mobo is. Isn't there a generic setting in MBM? Link to comment https://www.neowin.net/forum/topic/488794-motherboard-monitor/#findComment-587808350 Share on other sites More sharing options...
0 ryokovv006 Posted August 22, 2006 Share Posted August 22, 2006 mbm never worked for my laptop either.. try http://www.nordichardware.com/filearchive/fil,357.html Link to comment https://www.neowin.net/forum/topic/488794-motherboard-monitor/#findComment-587808357 Share on other sites More sharing options...
0 s|mOn Posted August 22, 2006 Share Posted August 22, 2006 I use this for Inspiron 6400. Don't know how accurate it is though. http://www.diefer.de/i8kfan/index.html Link to comment https://www.neowin.net/forum/topic/488794-motherboard-monitor/#findComment-587808381 Share on other sites More sharing options...
0 cheeseman557 Posted August 22, 2006 Author Share Posted August 22, 2006 Turns out I have a 0XD720. What board is similar to this one? I wanted to use MBM in conjunction with a Samurize config so all those other alternatives don't help, sorry :(. What is the generic setting you are talking about? I can't find it anywhere. Thanks. Link to comment https://www.neowin.net/forum/topic/488794-motherboard-monitor/#findComment-587809039 Share on other sites More sharing options...
0 Hooya Posted August 22, 2006 Share Posted August 22, 2006 Try using SpeedFan instead. It has fewer outputs, and the program needs to be running, but it will work much easier than MBM when used in conjunction with Samurize. Link to comment https://www.neowin.net/forum/topic/488794-motherboard-monitor/#findComment-587810000 Share on other sites More sharing options...
0 ranasrule Posted August 22, 2006 Share Posted August 22, 2006 yeah speedfan is much better than MBM Link to comment https://www.neowin.net/forum/topic/488794-motherboard-monitor/#findComment-587810022 Share on other sites More sharing options...
0 Echilon Posted August 23, 2006 Share Posted August 23, 2006 Ecion said: mbm never worked for my laptop either.. try http://www.nordichardware.com/filearchive/fil,357.html You can get that without registering here Link to comment https://www.neowin.net/forum/topic/488794-motherboard-monitor/#findComment-587811775 Share on other sites More sharing options...
cheeseman557
https://www.neowin.net/forum/topic/488794-motherboard-monitor/Share on other sites
7 answers to this question
