Gretzky399 Posted December 8, 2002 Share Posted December 8, 2002 I have a desktop that has a wireless card which it uses to access the internet. Also, I have a nic in the computer which is free and not in use. Now I want to be able to hook up my XBOX into the ethernet card so it can access the network through my wireless card!! How would I go about doing this so I can connect to XBOX Live through my wireless connection on my computer? Thanks Link to comment Share on other sites More sharing options...
SonicYouthXY Posted December 9, 2002 Share Posted December 9, 2002 I think when you connect the XBOX to the NIC, Windows XP will recognize it and prompt you to set up a home network. Then you can set up Internet Connection Sharing, so you can use it with XBOX Live. You can also run the Home Network Wizard at START | ALL PROGRAMS | ACCESSORIES | COMMUNICATIONS | NETWORK SETUP WIZARD Sonic. :woot: Link to comment Share on other sites More sharing options...
