CPressland Posted February 20, 2007 Share Posted February 20, 2007 Hey guys! hows it goin? ok so.. i've got this amazingly beautiful case and all but it's a screwless design and honestly it's complete crap. i was wondering.. how easy/hard would it be for me to setup my PC with no case. what precausions would i need to take etc? has anyone ever tried this before? can i just lay the whole thing out on a desk or do i need a large peice of wood/metal to put it on. Thanks for all your help. :p BTW. the PC in question: ASUS M2N32-SLi AMD Athlon X2 5000+ 2GB DDR2-800 RAM XFX 7600GT and 3 hard drives Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/ Share on other sites More sharing options...
Narc2500 Posted February 20, 2007 Share Posted February 20, 2007 Yes, I've done it... I left mine on top of my motherboard's box, on the antistatic sponge thingy. lol Although I did that until I got a case. Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588335690 Share on other sites More sharing options...
Trong Posted February 20, 2007 Share Posted February 20, 2007 Umm, make sure you don't short anything. That's all I can think of. It can work though, but it sounds like a bad idea to me... Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588335691 Share on other sites More sharing options...
XanoZuke Posted February 20, 2007 Share Posted February 20, 2007 What up Narc :p Back to the subject: I can be done, the only problem is that is not so easy to turn on :p and dust will cover it all if you don't take good care of it. Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588335704 Share on other sites More sharing options...
Knight85 Posted February 20, 2007 Share Posted February 20, 2007 I would STRONGLY advise against it. Common households have a TON of dust and this will go right into your system... it is hard enough keeping dust out with a case... this is like welcoming dust on to your most fragile parts. Also, you could potentially spill coffee/soda/water onto it and it will be entertaining (the sizzling sound), but you will lose your computer. And, if you have any pets, make sure they do not go trying to make a home in there (haha) Conclusion = Keep the case on... its like asking if you need to keep your pants on... well maybe not... your call! Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588335706 Share on other sites More sharing options...
shthead Posted February 20, 2007 Share Posted February 20, 2007 I don't have a case for mine, it just runs on my desk. Its a wooden desk and the mobo just sits on that... to turn it on just stick a screwdriver on the jump to trip it. If I used the computer everyday I would get a case though, but its only on once or twice a month :| Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588335708 Share on other sites More sharing options...
AudioDope Posted February 20, 2007 Share Posted February 20, 2007 Its been done!!!!!! Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588335711 Share on other sites More sharing options...
CPressland Posted February 20, 2007 Author Share Posted February 20, 2007 OK, thanks dudes, i think i'll save up for a new case... or a iMac Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588337082 Share on other sites More sharing options...
Technique Posted February 20, 2007 Share Posted February 20, 2007 Quote this is like welcoming dust on to your most fragile parts Oh dear :o Sorry to lower the tone, but it had to be done :D Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588337105 Share on other sites More sharing options...
j.r.l. Posted February 23, 2007 Share Posted February 23, 2007 Actually, I do it all the time to test things... it's pretty easy, just look in your motherboard manual to see where the power button connects to, it should be two little pins sticking out under your IDE connectors, beside your PCI slots. Just short these, and your computer should boot ^^ Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588344919 Share on other sites More sharing options...
SMELTN Posted February 23, 2007 Share Posted February 23, 2007 never done it before, but had a friend who did and it got all sticky from all the soda cans he was opening and them spewing all over it. hehe LOVE the pics though.. Would like to see some more no case pc pics Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588344992 Share on other sites More sharing options...
mikaelsnavy Posted February 23, 2007 Share Posted February 23, 2007 When I first got my computer parts, I put them into a cardboard box :) Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588345003 Share on other sites More sharing options...
Nicholas-c Veteran Posted February 25, 2007 Veteran Share Posted February 25, 2007 mikaelsnavy said: When I first got my computer parts, I put them into a cardboard box :) i dont advise it now if u overclock :p Link to comment https://www.neowin.net/forum/topic/540369-running-my-pc-without-a-case/#findComment-588349850 Share on other sites More sharing options...
