bigbeat808 Posted December 13, 2002 Share Posted December 13, 2002 I seem to have developed a strange IE6 problem. If I click on a link that opens in a new window, it will not load. The new IE box will come up but it just sorta hangs and never loads the page. Now I can have 2 instances of IE running, but I have to open each seperately. Also, now I appear to loose my internet connection to this PC after a period of time. I am on cable behind a router. I can still browse the network, but cant get out to the internet. The other PC's behind the router are not effected. Only thing I can do is reboot. I haven't changed anything to my knowledge, if you need more info just let me know... Running WinXP Pro SP1 Thanks, bigbeat808 Link to comment Share on other sites More sharing options...
Blaise Veteran Posted December 13, 2002 Veteran Share Posted December 13, 2002 This may help http://support.microsoft.com/default.aspx?...B;EN-US;q281679 Link to comment Share on other sites More sharing options...
bigbeat808 Posted December 13, 2002 Author Share Posted December 13, 2002 Thanks for the suggestion, but that didnt help! Link to comment Share on other sites More sharing options...
yzero Posted December 14, 2002 Share Posted December 14, 2002 I just spent 3 days trying to fix that so i just reinstalled ;/ Link to comment Share on other sites More sharing options...
bigbeat808 Posted December 14, 2002 Author Share Posted December 14, 2002 Trying to avoid it, but its looking more and more like thats the answer... bigbeat808 Link to comment Share on other sites More sharing options...
Prasanth Posted December 14, 2002 Share Posted December 14, 2002 Type these one by one on the run box regsvr32 Actxprxy.dll regsvr32 Shell32.dll regsvr32 Shdocvw.dll regsvr32 Oleaut32.dll regsvr32 Mshtml.dll regsvr32 Msjava.dll regsvr32 Browseui.dll regsvr32 Urlmon.dll Link to comment Share on other sites More sharing options...
unique Posted December 14, 2002 Share Posted December 14, 2002 Type these one by one on the run boxregsvr32 Actxprxy.dll regsvr32 Shell32.dll regsvr32 Shdocvw.dll regsvr32 Oleaut32.dll regsvr32 Mshtml.dll regsvr32 Msjava.dll regsvr32 Browseui.dll regsvr32 Urlmon.dll had the same problem and one of these worked for me...not sure which though.... :( Link to comment Share on other sites More sharing options...
bigbeat808 Posted December 14, 2002 Author Share Posted December 14, 2002 Thank you so much!! One of those fixed the problem, I just ran through them all and it now works! Thanks again! bigbeat808 Link to comment Share on other sites More sharing options...
