ReMad Posted April 3, 2007 Share Posted April 3, 2007 Hi My Friend just called me telling me his screen is flipped 90 degree to left in safe mode it is normal in the right position What is the settings that fixes this ? thank you Link to comment Share on other sites More sharing options...
Dick Montage Posted April 3, 2007 Share Posted April 3, 2007 This is a function of the driver. To resolve - go into control panel, display properties, settings, advanced, hunt around. Link to comment Share on other sites More sharing options...
fingers.t.beaver Posted April 3, 2007 Share Posted April 3, 2007 Nvidia and some other drivers put an icon in start bar right click on this go to the display and click on the rotation to sort it out. You may also want to follow the steps above and turn off the shortcut keys to stop this happening in future. Link to comment Share on other sites More sharing options...
Skiver Veteran Posted April 3, 2007 Veteran Share Posted April 3, 2007 this happens all the time at work with some on board graphics .... its usually one of the following to fix hold shift + alt then press the up arrow key hold shift + ctrl then press the up arrow key obviously it will be different for every mobo so id try what the other guys have said but thats how it works on these Link to comment Share on other sites More sharing options...
Gavin001 Posted April 3, 2007 Share Posted April 3, 2007 If u have ATI go to the System Tray right click the ATI icon and go to your graphics card then go to Rotate Desktop :) Link to comment Share on other sites More sharing options...
Brian M. Veteran Posted April 3, 2007 Veteran Share Posted April 3, 2007 this happens all the time at work with some on board graphics .... its usually one of the following to fixhold shift + alt then press the up arrow key hold shift + ctrl then press the up arrow key obviously it will be different for every mobo so id try what the other guys have said but thats how it works on these can also be ctrl + alt + up on some nvidia cards Link to comment Share on other sites More sharing options...
Stianu89 Posted April 5, 2007 Share Posted April 5, 2007 Just turn the monitor 90 degrees aswell :D IT's in the 3d card properties, look around and you will find it ;) Link to comment Share on other sites More sharing options...
