snyper Posted June 21, 2007 Share Posted June 21, 2007 (edited) Seiko Smart label Pinter 240 Im looking for where i might get the DC Cable for this..the regular 12 ac/dc adaptor that one can buy in a store for various things wont work..the port seems bigger on this... Any Ideas? Link to comment https://www.neowin.net/forum/topic/568777-power-cable-help-printer/ Share on other sites More sharing options...
Mindovermaster Global Moderator Posted June 21, 2007 Global Moderator Share Posted June 21, 2007 (edited) on the bottom lable, under the stand, it should say how much vampage/wattage you need what printer is that, anyway? Link to comment https://www.neowin.net/forum/topic/568777-power-cable-help-printer/#findComment-588642736 Share on other sites More sharing options...
snyper Posted June 21, 2007 Author Share Posted June 21, 2007 Quote what printer is that, anyway? Seiko Smart label Pinter 240 30 watt i believe Link to comment https://www.neowin.net/forum/topic/568777-power-cable-help-printer/#findComment-588642996 Share on other sites More sharing options...
Allan Posted July 6, 2007 Share Posted July 6, 2007 go to erm ... your local electronics store, and get a multi-voltage adapter with multiple connectors. Radio Shack erm, the Source by CC sells them here. Link to comment https://www.neowin.net/forum/topic/568777-power-cable-help-printer/#findComment-588678938 Share on other sites More sharing options...
snyper Posted July 6, 2007 Author Share Posted July 6, 2007 I tried that Allan, they do have a 12v cable but its a different size port.. :/ Link to comment https://www.neowin.net/forum/topic/568777-power-cable-help-printer/#findComment-588679298 Share on other sites More sharing options...
Allan Posted July 6, 2007 Share Posted July 6, 2007 That's what you need ... it provides multiple voltage settings, AND multiple adapters. Link to comment https://www.neowin.net/forum/topic/568777-power-cable-help-printer/#findComment-588679842 Share on other sites More sharing options...
MattL Posted July 7, 2007 Share Posted July 7, 2007 Worth checking eBay out, should be able to get one on there fairly cheaply. Link to comment https://www.neowin.net/forum/topic/568777-power-cable-help-printer/#findComment-588681589 Share on other sites More sharing options...
google123 Posted July 7, 2007 Share Posted July 7, 2007 Go here http://www.siibusinessproducts.com/support/index.html there is a link for spare parts for that printer. Its a PDF just download and call some numbers. :) Link to comment https://www.neowin.net/forum/topic/568777-power-cable-help-printer/#findComment-588681929 Share on other sites More sharing options...
snyper Posted July 7, 2007 Author Share Posted July 7, 2007 ^ u rock. Link to comment https://www.neowin.net/forum/topic/568777-power-cable-help-printer/#findComment-588682496 Share on other sites More sharing options...
google123 Posted July 7, 2007 Share Posted July 7, 2007 snyper said: ^ u rock. meh, its what it do. no problem :woot Link to comment https://www.neowin.net/forum/topic/568777-power-cable-help-printer/#findComment-588682519 Share on other sites More sharing options...
