Rudy Posted August 19, 2007 Share Posted August 19, 2007 I was wondering why my computer is reporting such low temperatures for my CPU. The case sensor says it's at 29C (that sounds right) but the CPU one says 17-18C (that's really low)...... My CPU is an E6750 (2.66 ghz core 2 duo) Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/ Share on other sites More sharing options...
myrhymeandreason Posted August 19, 2007 Share Posted August 19, 2007 Unless it is reporting incorrectly (which would be a problem because of inaccuracy and if it ended up being dangerously hot and not telling you), that should be a good thing. The lower the better, right? Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588790105 Share on other sites More sharing options...
Rudy Posted August 19, 2007 Author Share Posted August 19, 2007 well that's the problem, im guessing it's incorrect since it's so low.....i am using the heatsink that came with the cpu... Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588790107 Share on other sites More sharing options...
The Angry Bunny Posted August 19, 2007 Share Posted August 19, 2007 Hmm... this might just be me being tired, but that sorta sounds right to me. I mean I've heard nothing but praise for the Core 2's temps, and considering my old AMD Barton is running at a steady 28-30 ish range on a stock cooler, that seems like it'd be acceptable. Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588790111 Share on other sites More sharing options...
myrhymeandreason Posted August 19, 2007 Share Posted August 19, 2007 I am assuming the answer is no, but just to be sure: You haven't changed any hardware at all? What about any programs like Speedfan? When did you notice this? Just randomly, or it has been like that for a while? Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588790112 Share on other sites More sharing options...
The Angry Bunny Posted August 19, 2007 Share Posted August 19, 2007 Hmm... after thinking about it a bit longer it does seem a lil odd... try download motherboard monitor and see what it says... Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588790117 Share on other sites More sharing options...
12Iceman Posted August 19, 2007 Share Posted August 19, 2007 I was wondering why my computer is reporting such low temperatures for my CPU. The case sensor says it's at 29C (that sounds right) but the CPU one says 17-18C (that's really low)......My CPU is an E6750 (2.66 ghz core 2 duo) Depending on what software you are using, it could be reading it wrong (due to the 85C vs. 100C TJunction issue). Most likely you need to add 15C to each of the core temps which would give you around 33C which is reasonable considering your case temp is 29C. Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588790121 Share on other sites More sharing options...
Rudy Posted August 19, 2007 Author Share Posted August 19, 2007 well i was getting the reading from the bios....i felt the heatsink and it does feel really cool im installing Motherboard monitor..... edit: won't run on Vista x64..... Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588790123 Share on other sites More sharing options...
Rudy Posted August 19, 2007 Author Share Posted August 19, 2007 got SpeedFan to run....shows core0 and core1 running idle at 20-22C and i tried to run super pi (i know it's outdated) and the max i got was 30-31C.....i mean i knew the core 2 duo were cool but this is REALLY cool....sounds fishy to me... but then when i put my hand at the back of the computer the air coming out is really cool (can't check the heatsink because the case is closed) Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588790139 Share on other sites More sharing options...
RadishTM Veteran Posted August 19, 2007 Veteran Share Posted August 19, 2007 Try Core Temp - http://www.thecoolest.zerobrains.com/CoreTemp/ Radish? Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588790812 Share on other sites More sharing options...
J400uk Posted August 19, 2007 Share Posted August 19, 2007 Lucky you, I get arround 50 degs on both my c2d systems. Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588790822 Share on other sites More sharing options...
capr Posted August 19, 2007 Share Posted August 19, 2007 i have liquid cooling on a e6600 and my temp is around 31-33 when it's just sitting there... so I really don't think you are getting the right temps. or my liquid cooling just sucks... Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588791026 Share on other sites More sharing options...
dr.bisho Posted August 19, 2007 Share Posted August 19, 2007 lucky you, did you try to use another cpu on that mother board, or try another motherboard on the same system, that will make you certain of whats wrong, but i suggest , your mother board is acting stupid :p Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588791064 Share on other sites More sharing options...
Popcorned1 Posted August 19, 2007 Share Posted August 19, 2007 That's really strange (especially on the stock air cooler) and wouldn't trust those fully until you know for sure all your hardware is working properly. If it is right. I wouldn't moan too much, you'd be able to get some insane overclocks on that thing. Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588791075 Share on other sites More sharing options...
Rudy Posted August 19, 2007 Author Share Posted August 19, 2007 here's a screenshot of Core temp....same thing as Speedfan was giving me.....idle at 20-22 and full load in the low 30s.....im glad i have a really cool cpu but im kinda scared the reading is wrong.......but core temp says in the readme that it uses the temperature from the cpu itself.....im kinda confused Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588791272 Share on other sites More sharing options...
The Angry Bunny Posted August 20, 2007 Share Posted August 20, 2007 I was thinking of this... You obviously have one of the latest core 2 models to come out, so could that be what it is? Maybe they enhanced the temp of the procs even more with this model. Just a thought. Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588792053 Share on other sites More sharing options...
kouhii00 Posted August 20, 2007 Share Posted August 20, 2007 here's a screenshot of Core temp....same thing as Speedfan was giving me.....idle at 20-22 and full load in the low 30s.....im glad i have a really cool cpu but im kinda scared the reading is wrong.......but core temp says in the readme that it uses the temperature from the cpu itself.....im kinda confused If you look at the vcore it's running at 1.1V and if you look at others it's running at around 1.3V that's probrably why your temps are lower? You should look at intel's websites and look up the datasheet on the new intel procs it might shed some light. Rule of thumb, lower voltage=lower temps because P=I*V, P is power in watts(Joules/sec), I is current (Amps), and V is voltage. Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588792063 Share on other sites More sharing options...
Rudy Posted August 21, 2007 Author Share Posted August 21, 2007 updated the bios and in the bios it now reads about 30C idle....sounds more like it....still low :p but then the air coming out the back of the computer is really cool Link to comment https://www.neowin.net/forum/topic/582122-low-cpu-temps/#findComment-588794821 Share on other sites More sharing options...
