Hellgod Posted August 27, 2007 Share Posted August 27, 2007 When my pc is not in this desk it's happy in it it over heats i have 2 rear fans blowing out 80mm, and the PSU has two fans one sucks up from cpu and one goes out, the front panel comes in, (blocked by the hd's) and the side panel going out thanks Link to comment https://www.neowin.net/forum/topic/583951-fan-layout-overheating-in-desk/ Share on other sites More sharing options...
DrivenDaily Posted August 27, 2007 Share Posted August 27, 2007 Is the desk open behind the computer? If not, there isn't anywhere for the hot air to go. Link to comment https://www.neowin.net/forum/topic/583951-fan-layout-overheating-in-desk/#findComment-588808302 Share on other sites More sharing options...
tao muon Posted August 27, 2007 Share Posted August 27, 2007 Definitely cut the fiber-board behind the tower's location in that desk. Also, move the desk about 1/2 to 1 inch away from the wall, if you can. Link to comment https://www.neowin.net/forum/topic/583951-fan-layout-overheating-in-desk/#findComment-588808308 Share on other sites More sharing options...
Lord Zog Posted August 27, 2007 Share Posted August 27, 2007 Cut out some holes in the back of the desk where the PC is, your hot air is staying in the desk. :) Link to comment https://www.neowin.net/forum/topic/583951-fan-layout-overheating-in-desk/#findComment-588808313 Share on other sites More sharing options...
Hellgod Posted August 27, 2007 Author Share Posted August 27, 2007 Cut out some holes in the back of the desk where the PC is, your hot air is staying in the desk. :) It's completely open, WITH the AC Vent behind it It's completely open, WITH the AC Vent behind it Part of my issue is i have the 7800 GTX and it's as long as the case, so the front intake fans cant flow air to the uper part of the case, and there is no where else to put fans in the front, SO i ordered a bigger (deeper case) with 120mm fans to see if that helps and hte new one has a cool UV Glass :) Link to comment https://www.neowin.net/forum/topic/583951-fan-layout-overheating-in-desk/#findComment-588808321 Share on other sites More sharing options...
bryonhowley Posted August 27, 2007 Share Posted August 27, 2007 Cut out some holes in the back of the desk where the PC is, your hot air is staying in the desk. :) I would allso recoment you move the desk from the wall some. A few inches would be enough becouse as it is your computer is just sucking the hot air back into the case. Link to comment https://www.neowin.net/forum/topic/583951-fan-layout-overheating-in-desk/#findComment-588808325 Share on other sites More sharing options...
