Damn Small Linux - WN825G
Hi, I have the Motorla Wireless card listed in the title, and can't get it to work. I've downloaded the 1.1 drivers from the internet, copied them to my laptop, and used ndiswrapper -i and modprobe ndiswrapper to get it running. The card lights up, but from there on I'm stuck.
Using pump -i reports Operation Failed.
Using iwconfig I can only set the encryption key. If I try to set the ESSID and then check the status it reports off/any still.
I've got no idea what to do now, anybody got this to work?
https://www.neowin.net/forum/topic/586919-damn-small-linux-wn825g/
Here is how someone got it to work in Mepis. http://www.mepis.org/node/5047
The concept should pretty much transfer to DSL.
Sorry, I don't use wireless in Linux, so I cannot be more specific.
