Urgent mIRC help
6 answers to this question
usually it's listed at the top of the message so that should work. or you can simply just ask in the room you are in... that's the first thing since that's faster.... most bots use the command:
/msg xdcc send #
just fill in the blanks and you're ready to go..
https://www.neowin.net/forum/topic/6110-urgent-mirc-help/#findComment-41478
It's just "get filename.ext" you don't need the "/". also, sometimes files show up as "here is the file.xxx" but it's really "here_is_the_file.xxx". The only way to make sure you're typing it in correctly is to copy and paste the filename.
good luck, mIRC is an awsome resource.
https://www.neowin.net/forum/topic/6110-urgent-mirc-help/#findComment-41484
