Thrawn Posted January 29, 2008 Share Posted January 29, 2008 It won't take off. $20 I was going to say "Paypal, done." But its immoral to gamble! Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169370 Share on other sites More sharing options...
Rohdekill Posted January 29, 2008 Share Posted January 29, 2008 The laws of physics should be universal right? I say yes, plane will take off. I've a previous experiment to verify my hypothesis. So lets say my test case is a human running on a treadmill, call him the unexpecting classmate. Now, if unexpecting classmate can go flying-off a treadmill - and humans are not meant to fly - does this not mean that same principal applied to an airplane, which is meant to fly- would work? I think so. *This is wrong on so many levels, including experimenting on humans which I do not condone. Answer me this. While running on treadmill, do you feel a breeze you create from running? No!! No breeze, no lift. Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169376 Share on other sites More sharing options...
Astra.Xtreme Posted January 29, 2008 Share Posted January 29, 2008 If lift is dependent on velocity, then once that certain velocity is reached, it will create lift. The plane should be reliant on the ground to get that necessary velocity needed for life. Once it's in the air, it shouldn't go below that velocity, so you can't compare that. Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169382 Share on other sites More sharing options...
+Xinok Subscriber² Posted January 29, 2008 Subscriber² Share Posted January 29, 2008 I'll try to explain this as simply as possible: The plane is moving forward at 20mph. This means the conveyor belt is moving in the opposite direction at 20mph. This means the wheels are moving at 40mph. Think of it this way: You're on a conveyor belt, and you're on a skateboard. (or wearing a pair of skates, whatever makes you happy). You're pulling on a rope to pull you forward. Is the conveyor belt gonna prevent you from moving forward? No. The same concept applies to this myth. Instead of pulling on a rope, the jet engines essentially "pull" on the air to move the plane forward. Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169385 Share on other sites More sharing options...
HawkMan Posted January 29, 2008 Share Posted January 29, 2008 it WONT be stationary. the conveyor will be moving back at the same speed as the plane's forward speed. but the trick is that the plane's speed is NOT dependent on the GROUND (otherwise how the HECK do you think it flies after leaving the ground?!). the plane moves by pushing the air back and not the ground back.so what happens is that the conveyor's speed is totally irrelevant to the plane. it will still move forward, because it doesn't depend on the ground to move forward (only to keep it from "falling to the center of the earth" while it doesn't have enough windspeed to sustain itself). the plae still has weight pushing down. now say the conveyor belt is moving backward at practically unlimited speed. the engines would need to give the same force to keep the plane stationary(yeah the conveyor belt moves backward at the same speed as the plane "would" have moved forward, but t's the same thing) In addition to this to get th eplane moving forware it would need to at least doule that force again. afterall the myth says the converyor belt moves as fast as the plane can ever counter. so the converor would essentially be pushign the plane backwards at it's own weight. but then agai, I voted for the plane taking off :) but seeing as the pilot guesed wrong, I'm trying to figure out how it could not take off... Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169387 Share on other sites More sharing options...
Rohdekill Posted January 29, 2008 Share Posted January 29, 2008 i contacted the leader of a RC plane club a while ago over this and he said it wouldn't take off in theory, i reckon the same but lets see where mythbusters take this... like some dweeb from an RC plane club is an expert. lol Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169392 Share on other sites More sharing options...
BroChaos Veteran Posted January 29, 2008 Veteran Share Posted January 29, 2008 i can't even remember what the original questions was anymore.... and who has that funny animated gif signature?? Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169393 Share on other sites More sharing options...
kaffra Posted January 29, 2008 Share Posted January 29, 2008 Probably on a smaller aircraft where the propeller provides some airflow across the wings. the key is the airflow across the wings. no lift no take off. i dont see this possible with the bigger jets, the engines are used to provide trust. and as the plane is moving forward, the airflows across the wings to provide the necessary lift. if the plane is standing still(because of the conveyor belt) and the exhaust air of the engine doesnt flow across the wings, then i dont see it taking off. Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169408 Share on other sites More sharing options...
Astra.Xtreme Posted January 29, 2008 Share Posted January 29, 2008 I think you guys are thinking too much into reality. They are testing it as if there were a possible way to keep the plane stationary by using a conveyor belt. Or am I wrong? If they are testing if the plane will outrun the conveyor, then that's obvious that it will. Also, wouldn't just setting the brakes and blasting the engines have the same effect as to having it roll on a belt? Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169413 Share on other sites More sharing options...
GrimReeper Posted January 29, 2008 Share Posted January 29, 2008 I think we should either post a link to the old topic or wait for mythbusters. I remember the original neowin post, when I opened this new one I was like "omg here we go again :pinch: " Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169416 Share on other sites More sharing options...
Galley Posted January 29, 2008 Share Posted January 29, 2008 I was able to get an airplane to hover once. (40 mph flight speed into a 40 mph head wind) Does that count for anything? :p Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169429 Share on other sites More sharing options...
Hooya Posted January 29, 2008 Share Posted January 29, 2008 I'll try to explain this as simply as possible:The plane is moving forward at 20mph. This means the conveyor belt is moving in the opposite direction at 20mph. This means the wheels are moving at 40mph. Think of it this way: You're on a conveyor belt, and you're on a skateboard. (or wearing a pair of skates, whatever makes you happy). You're pulling on a rope to pull you forward. Is the conveyor belt gonna prevent you from moving forward? No. The same concept applies to this myth. Instead of pulling on a rope, the jet engines essentially "pull" on the air to move the plane forward. At least somebody else in this thread understands physics! Thank you for restoring my faith in the human brain. They are testing it as if there were a possible way to keep the plane stationary by using a conveyor belt. Or am I wrong? That is indeed what they are essentially testing. There is NO WAY the conveyor has ANYTHING to do with the thrust of the engines, and therefore the speed the plane will move while on the ground. All that will happen is the wheels will spin faster than they would if they weren't on a conveyor. That's all. The plane will act as if the conveyor wasn't there in every other way (unless the steering is controlled by the wheels, in which case they're screwed!!!) Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169450 Share on other sites More sharing options...
Doli Posted January 29, 2008 Share Posted January 29, 2008 Do MythBusters ever have experiments go wrong and still show it on TV? I just dont see how that can pull this off getting the speed right with a large conveyor belt and the weather condition (wind). Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169511 Share on other sites More sharing options...
Fred 69 Posted January 29, 2008 Share Posted January 29, 2008 I think the plane will take off. My reasoning behind it- If the plane wasn't moving and the conveyor belt was: Wheels wouldn't move and plane would be moved backwards. If the plane was moving and the conveyor belt wasn't: Wheels would move as the plane moves through the "air" to allow it roll over the ground. If both the plane and the conveyor belt is moving: Initially the plane will be stationary but as it speeds up the plane will reach nearer to the speed the engines are pulling air at while the conveyor belt will be moving at the same speed the engines are pulling air at, BUT the wheels will be spinning the sum of these. So while the plane's engines will be running at say 500Kph and the conveyor belt at 500Kph, the wheels at (perhaps not exactly?) 1000Kph, the velocity of the plane will be increasing steadily towards 500Kph but never quite reach it until the plane lifts off. At least that's how I understand it. Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169518 Share on other sites More sharing options...
Lewism Posted January 29, 2008 Share Posted January 29, 2008 Do MythBusters ever have experiments go wrong and still show it on TV?I just dont see how that can pull this off getting the speed right with a large conveyor belt and the weather condition (wind). Watch Wednesday's show and see it Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169523 Share on other sites More sharing options...
shakey_snake Posted January 29, 2008 Share Posted January 29, 2008 (edited) I'll try to explain this as simply as possible:The plane is moving forward at 20mph. This means the conveyor belt is moving in the opposite direction at 20mph. This means the wheels are moving at 40mph. Think of it this way: You're on a conveyor belt, and you're on a skateboard. (or wearing a pair of skates, whatever makes you happy). You're pulling on a rope to pull you forward. Is the conveyor belt gonna prevent you from moving forward? No. But it will take twice as much force on the rope for you to overcome your inertia and begin moving forward...The conveyor belt functions exactly like an incline (minus the angle of attack issues with the airfoils) The question is, does the plane have enough engine power? Will the engine be able to hit it's "power band"? So, I say, this depends on the plane. The smaller the plane, the more likely, since the engine power/weight ratio changes as the plane scales. Edited January 29, 2008 by shakey_snake Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169535 Share on other sites More sharing options...
HawkMan Posted January 29, 2008 Share Posted January 29, 2008 it's a micrlight, it'll take off it you sneeze hard enough :p Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169556 Share on other sites More sharing options...
golemn Posted January 29, 2008 Share Posted January 29, 2008 The jet plane will fly, the wheels do not affect the speed of the aircraft at all. Everyone that thinks it wont is thinking that the wheels are what create thrust. The wheels spin freely has nothing to do with the plane. Just imagine it and it will become clear. Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169557 Share on other sites More sharing options...
gigapixels Veteran Posted January 29, 2008 Veteran Share Posted January 29, 2008 The jet plane will fly, the wheels do not affect the speed of the aircraft at all. Everyone that thinks it wont is thinking that the wheels are what create thrust. The wheels spin freely has nothing to do with the plane. Just imagine it and it will become clear. No, nobody's thinking that the wheels create the thrust, we're saying that the motion of the plane through the air will create lift... Since it's not moving through the air, it's not creating lift. Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169583 Share on other sites More sharing options...
HawkMan Posted January 29, 2008 Share Posted January 29, 2008 The jet plane will fly, the wheels do not affect the speed of the aircraft at all. Everyone that thinks it wont is thinking that the wheels are what create thrust. The wheels spin freely has nothing to do with the plane. Just imagine it and it will become clear. Must be why all those planes keep rolling off the carriers when they start moving. noones saying the wheels is propelling the plane or that the wheels aren't spinning freely. but let's scale this thing up from the microlight they are testing with. put a passenger jet weighting over a hundred tons or so on a conveyor and start moving the conveyor backward, no matter how freely the wheels spin, the Jet engines will need to provide twice the thrust to keep the plane still to keep it moving forward as fast as the converyor moves back. and that's not counting that the conveyor is moving backward at the same speed as the plane "would" be moing forward. on the other hand, the conveyor doesn't start moving untill the wheels do, wich means by the time the converyor is countermoving to the wheels, the plane has allready achieved momentum, wich makes it unlikely the conveyor woudl ever be able to counter this momentum. But this is only a propelm iin reality, not in the thought experiment where there would be no such lag. Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169602 Share on other sites More sharing options...
golemn Posted January 29, 2008 Share Posted January 29, 2008 (edited) No, nobody's thinking that the wheels create the thrust, we're saying that the motion of the plane through the air will create lift... Since it's not moving through the air, it's not creating lift. hmm, the plane will move through the air. Lets say i am on a trendmill on a skateboard thats attached to me. I am holding a rope attached to a car. The car accelerates, i am going to fly off that trendmill on the skateboard the bearings spin freely. Now if i had wings, and reached 140 mph ( varies on wing span and weight ) I would literally fly. The thrust coming from the jet engines is like the acceleration from the car. I dont think I painted a good enough picture, but of this i am certain. The plane will create lift and fly. Must be why all those planes keep rolling off the carriers when they start moving.noones saying the wheels is propelling the plane or that the wheels aren't spinning freely. You know they have the wheel locks... I have seen one roll off a carrier... Where in Norway do you live Hawkman, I have been there multiple times? Edited January 29, 2008 by golemn Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169606 Share on other sites More sharing options...
The_Decryptor Veteran Posted January 29, 2008 Author Veteran Share Posted January 29, 2008 The important part to remember is:If the pilot guessed wrong, it must be the opposite of what everyone assumes. I was talking to a pilot (at least he claimed he was one), and he swore that planes couldn't take off using engine power alone. Don't assume they know the right answer (or even how a plane works). Answer me this. While running on treadmill, do you feel a breeze you create from running? No!! No breeze, no lift. Answer me this. Are you an airplane? The most common problem with this question, is people start thinking the plane behaves with a car (probably because the type of ground it's on is specifically mentioned), airplanes don't move by spinning the wheels, they move by using their engines (which pulls/pushes the entire plane forward) Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169640 Share on other sites More sharing options...
sundayx Veteran Posted January 29, 2008 Veteran Share Posted January 29, 2008 It pushes the plane forward so enough air can move through the wings. The engines don't give the plane lift, the wings does. Being on the treadmill, there won't be enough air through the wings, only through the engines, which is working it's ass off trying to draw air in. Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169644 Share on other sites More sharing options...
spenser.d Posted January 29, 2008 Share Posted January 29, 2008 scratch that. Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169655 Share on other sites More sharing options...
Nomad_ Posted January 29, 2008 Share Posted January 29, 2008 What would happen If a plane landed on a conveyor belt moving in the opposite direction at the planes landing speed? :D Link to comment https://www.neowin.net/forum/topic/616462-mythbusters-tackles-plane-on-a-conveyor-belt-problem/page/7/#findComment-589169658 Share on other sites More sharing options...
