Badie05 Posted March 21, 2008 Share Posted March 21, 2008 I want to know if the Sony's PSP Memory Stick Pro Duo cards work alone or with the provided adapter in the Nintendo Wii? Link to comment Share on other sites More sharing options...
Rudy Posted March 21, 2008 Share Posted March 21, 2008 no, the wii uses sd cards Link to comment Share on other sites More sharing options...
Badie05 Posted March 21, 2008 Author Share Posted March 21, 2008 I know that but can I use that adapter and put it in like that? :( I have a spare Lexar 1GB Pro Duo and an adapter and i don't want to shell out for a 1-2GB SD card ;P Link to comment Share on other sites More sharing options...
+Matthew S. Subscriber² Posted March 21, 2008 Subscriber² Share Posted March 21, 2008 So you'd rather use an in-compatible card through an adapter then buy a real 1gb sd card for $10CAD? Anyways I don't see why it wouldn't work. Link to comment Share on other sites More sharing options...
Luis.A Posted March 21, 2008 Share Posted March 21, 2008 That adapter wont work. Buy an SD. Link to comment Share on other sites More sharing options...
Badie05 Posted March 21, 2008 Author Share Posted March 21, 2008 10 dollars? where. That is cheap :p Link to comment Share on other sites More sharing options...
Kraftman Posted March 21, 2008 Share Posted March 21, 2008 10 dollars? where. That is cheap :p I hope to god you have $11. http://www.ncix.com/products/index.php?sku...mp;promoid=1065 http://www.ncix.com/products/index.php?sku...mp;promoid=1065 Link to comment Share on other sites More sharing options...
Badie05 Posted March 21, 2008 Author Share Posted March 21, 2008 Thanks :D! Link to comment Share on other sites More sharing options...
+Matthew S. Subscriber² Posted March 21, 2008 Subscriber² Share Posted March 21, 2008 tiger.ca also has em for $10 Link to comment Share on other sites More sharing options...
PL_ Veteran Posted March 21, 2008 Veteran Share Posted March 21, 2008 I know that but can I use that adapter and put it in like that? It's a Memory Stick Duo to Memory Stick adaptor. That'll still only go in a Memory Stick slot, just to clear up any confusion there. Link to comment Share on other sites More sharing options...
+Matthew S. Subscriber² Posted March 21, 2008 Subscriber² Share Posted March 21, 2008 ^ man I'm slow I just realized that it's a Memory Stick Duo to Memory Stick adapter :| Link to comment Share on other sites More sharing options...
whYeNQue Posted March 22, 2008 Share Posted March 22, 2008 amazon.co.uk are selling the proper 2gig wii sd cards for ?3.44 http://www.amazon.co.uk/gp/product//B000KKIQ9C/ref=br_fq_ Link to comment Share on other sites More sharing options...
+Matthew S. Subscriber² Posted March 22, 2008 Subscriber² Share Posted March 22, 2008 ^ how is it "proper"? Link to comment Share on other sites More sharing options...
Badie05 Posted March 23, 2008 Author Share Posted March 23, 2008 So the adapter will work? By the way proper means labeled with Wii for no apparent reason :p. Link to comment Share on other sites More sharing options...
Brandon Posted March 23, 2008 Share Posted March 23, 2008 So the adapter will work? By the way proper means labeled with Wii for no apparent reason :p. Damnit no. The adapter won't work. The adapter allows you to use SONY's duo in a regular SONY memory stick slot (ie SONY camera and SONY laptops) Link to comment Share on other sites More sharing options...
