  Badie05 said:
I am look for E.A.X 5.0 compatible sound cards...just a list. So far I have the the Prelude which is expensive...what else is there?
You need to either spend money on a good card or just use the built in audio.
Avoid Creative, they are always a long-term disapointment. (And I've used almost all of them)
But I warn you, it's NOT true EAX 5.0, it's an emulation mostly done on the CPU.
But with today's CPUs and the death of EAX in Vista, you will not see new super games with EAX so it's just old games.
The Xonar DX is $10 cheaper than the Creative X-Fi Xtreme Gamer. Though the X-Fi do real Hardware EAX 5.0 (IN XP ONLY, in Vista, EAX > OpenAL isn't perfect and use CPU) the card look WAY less good quality.
(PCI-E x1 don't bring you nothing in fact than just a use for that slot where PCI are phasing out)
NCIX Asus Xonar DX $90
Creative Labs Sound Blaster X-FI Xtreme Gamer $99
Review where Creative's Xtreme Music card get mostly owned face to the Xonar :p
Edited by NienorGT
you guys are pretty picky :p
i have the Xtrememusic w/ Vista and it's great. ive never had a single issue and EAX5 works fine.... although not that many games use it afaik.
in fact, ive only owned two sound cards, both are Creative. the SBLive! was the other... i used that thing for like 7yrs and it was awesome.
