keys not working on Logitech Dinovo Edge
everything is working except the keys.
Working: Fn +F1/ F2..
Programmable keys
Mousepad on the keyboard
Volume bar
Not working: all the letters, numbers, win key ctrl alt del.
is there something wrong with my keys or have i just switch off something?
Is this a new keyboard? Or did it suddenly stop working when you were using it.
Call Logitech, their customer support is FANTASTIC, chances are they'll send you a new one straight away if it's that broken :)
-Rich-
it stop working suddenly when i was using it.
-Rich-
i know this is my second one because one of the keys pop out when i had my first. I'm trying to solve it first before i called them up.
okay so it works on my friend's laptop but not on my comp. hmm.
the only i installed before that was the window malicious update. then it happened.
