DANIZX9 Posted August 14, 2008 Share Posted August 14, 2008 I get this resolution on youtube on a 1680x1050 full screen for some reason, does anyone know how to fix it? I reinstalled adobe flash but that didnt fix it Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/ Share on other sites More sharing options...
Des Posted August 14, 2008 Share Posted August 14, 2008 I think its the way the video was recorded and scaled down bro, so it's probably not possible to view it in full resolution. Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589652426 Share on other sites More sharing options...
DANIZX9 Posted August 15, 2008 Author Share Posted August 15, 2008 Dez3rt.Eagle said: I think its the way the video was recorded and scaled down bro, so it's probably not possible to view it in full resolution. im not talking about the video, i just used a video to prove my point. im actually taking about how the player looks the "press esc to exit full screen mode" and the bottom bar also looks as if its on a lower resolution its too big even thou i'm on 1680x1050 it only does this on youtube. Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589652704 Share on other sites More sharing options...
ATGC Posted August 15, 2008 Share Posted August 15, 2008 That's how it is for youtube's player on fullscreen. Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589653010 Share on other sites More sharing options...
The_Decryptor Veteran Posted August 15, 2008 Veteran Share Posted August 15, 2008 Yep, that's just how it is. Edit: It's silly and I don't know why it's like that though. Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589653100 Share on other sites More sharing options...
Rappy Veteran Posted August 15, 2008 Veteran Share Posted August 15, 2008 NeptuneSaK said: That's how it is for youtube's player on fullscreen. Yeah its really bad and they really need to improve it Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589653112 Share on other sites More sharing options...
Menge Posted August 15, 2008 Share Posted August 15, 2008 i get full resolution. i don't know what's the difference. Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589653144 Share on other sites More sharing options...
ozgeek Posted August 15, 2008 Share Posted August 15, 2008 Yep it's normal. If you are talking about the black left and right parts that's because you have a widescreen monitor and the video is not a widescreen-formatted video. And I do get the seekbar (the bottom bar) in fullscreen and the text about "Pressing Esc.." goes off by itself after about a second or two into the full screen mode. Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589653198 Share on other sites More sharing options...
Code.Red Posted August 15, 2008 Share Posted August 15, 2008 Yeah, I used to get what Menge posted, but a few weeks ago(?) they must have changed it as I get what you are getting. Curious. Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589653216 Share on other sites More sharing options...
Menge Posted August 15, 2008 Share Posted August 15, 2008 Windows Vista + Aero? i get the same as the first poster on OS X (which is why i think the desktop composition engine does it). my XP machine gets full res, though. Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589653232 Share on other sites More sharing options...
+Gary7 Subscriber² Posted August 15, 2008 Subscriber² Share Posted August 15, 2008 I just tried it in full screen mode and the image was almost perfect. Vista + Aero Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589653236 Share on other sites More sharing options...
MasterC Posted August 15, 2008 Share Posted August 15, 2008 I used to get it normally like the Rickroll video posted above, but lately I've been getting the chunky version. Really sucks on 2560x1600. :/ Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589653240 Share on other sites More sharing options...
DANIZX9 Posted August 15, 2008 Author Share Posted August 15, 2008 Menge said: i get full resolution. i don't know what's the difference. yours displays correctly with the Thin bar at the bottom this is what i was talking about, all along. im trying to get mine like that Link to comment https://www.neowin.net/forum/topic/657660-help-youtube-flash-full-screen-resolution-help/#findComment-589657064 Share on other sites More sharing options...
