WorkSpacer Posted July 7, 2009 Share Posted July 7, 2009 Cordial Greetings, I've got a custom built computer that's almost 2 years old now, Intel Core2 Quad Q6600 on a P5K-E WiFi motherboard with a Zalman CNPS-9700LED heatsink. Has been running pretty much perfectly for the last two years. Just today, when I got back from work, turned my computer on; the heatsink was very loud. So I unplugged my computer, put it on a blank desk then spent the better part of an hour cleaning/clearing the dust out. Plugged everything back in, but unfortunately the problem still occurs. :pinch: I've also tried changing the fan speed manually, to no avail. Please recommend a method for fixing my heatsink. Thank you, Work s p a c e r BTW: I still have the HeatSink which came with somewhere, so if the worst comes to worst I can use that. Link to comment Share on other sites More sharing options...
jwjw1 Posted July 7, 2009 Share Posted July 7, 2009 sounds like one of the bearings went out on the 110mm fan...not real sure if that fan is replaceable. Maybe someone knows and will post or you can contact Zalman. http://www.zalman.com/eng/product/Product_Read.asp?Idx=164 Link to comment Share on other sites More sharing options...
Krispy Kritter Posted July 7, 2009 Share Posted July 7, 2009 And just for clarification, it's not exactly the heatsink that is making noise, it's the heatsink fan. The heatsink is the actual chunk of aluminum and copper. But I agree, you need a new fan. You should be able to purchase an exact replacement from the manufacturer. Or you could likely get something else to work with a little modification. There are several vendors with fans, I recommend FrozenCPU. http://www.frozencpu.com/cat/l1/g36/Fans.html?id=E8tgJSd6 Link to comment Share on other sites More sharing options...
i_was_here Posted July 8, 2009 Share Posted July 8, 2009 http://sharkacomputers.com/10050-zm-rp-110-pwm.html Link to comment Share on other sites More sharing options...
Yusuf M. Veteran Posted July 8, 2009 Veteran Share Posted July 8, 2009 Yep. You'll need to replace the fan on the heatsink. Check out the links that were posted so far. They should be helpful! :) Link to comment Share on other sites More sharing options...
WorkSpacer Posted July 8, 2009 Author Share Posted July 8, 2009 Thanks for the replies everyone. I've emailed the people who I bought the hardware from, and am waiting for a reply from them, as it may be still under warranty. Otherwise, I would think replacing it with the generic Intel heatsink/fan would be my best & cheapest choice? Would you agree? Link to comment Share on other sites More sharing options...
+jamesyfx Subscriber² Posted July 8, 2009 Subscriber² Share Posted July 8, 2009 Yeah there is nothing wrong with the stock fan/heatsink, it's a great cooler. Link to comment Share on other sites More sharing options...
jwjw1 Posted July 8, 2009 Share Posted July 8, 2009 Thanks for the replies everyone.I've emailed the people who I bought the hardware from, and am waiting for a reply from them, as it may be still under warranty. Otherwise, I would think replacing it with the generic Intel heatsink/fan would be my best & cheapest choice? Would you agree? the warranty shows to be 1 year. That is a pretty good cooler and replacing the fan @ 14.95 would be a good investment. But its your decision. https://www.neowin.net/forum/index.php?show...amp;p=591246228 Link to comment Share on other sites More sharing options...
WorkSpacer Posted July 8, 2009 Author Share Posted July 8, 2009 ^Why did you quote a link to this topic? jwjw1: I have a certification I'm training for, whose training I need to finish within the next week. So I don't really have the time to order something from the US. Thanks JamesYFX - I'll pick up the stock cooler tomorrow. Link to comment Share on other sites More sharing options...
WorkSpacer Posted July 9, 2009 Author Share Posted July 9, 2009 Greetings once again, After replacing with the stock cooler, the noise was still happening. Ended up finding the cause, a faulty IDE Hard-Drive. So now I find myself in a little predicament... should I put the 3rd party heatsink back in, or keep the generic? Link to comment Share on other sites More sharing options...
Raa Posted July 9, 2009 Share Posted July 9, 2009 Damn that noisy heatsink! You should've got gold instead of copper, I hear it's a lot quieter... Especially when shown in large amounts. Well, the effect usually lasts a few seconds at least. ;) Glad you found the problem! Use the original though! Link to comment Share on other sites More sharing options...
i_was_here Posted July 9, 2009 Share Posted July 9, 2009 Put back the Zalman. Link to comment Share on other sites More sharing options...
WorkSpacer Posted July 9, 2009 Author Share Posted July 9, 2009 Arghh... put back the Zalman or leave the Generic? BTW: Some of the outer copper on the Zalman has been bent, whilst I was cleaning it. And I'm out of Thermal Grease. Would it still be alright to use? Link to comment Share on other sites More sharing options...
i_was_here Posted July 9, 2009 Share Posted July 9, 2009 Buy some thermal grease then put the Zalman back on. Otherwise just stay with the generic. Link to comment Share on other sites More sharing options...
WorkSpacer Posted July 11, 2009 Author Share Posted July 11, 2009 Okay, I;'ll go buy some now. Quick Question: Does anyone know which way it should be facing? Toward the RAM, the GFX or the outside of the case? Link to comment Share on other sites More sharing options...
Raa Posted July 11, 2009 Share Posted July 11, 2009 Towards the outside of the case - the hot air needs to escape the computer, not remain inside it. :) Link to comment Share on other sites More sharing options...
WorkSpacer Posted July 11, 2009 Author Share Posted July 11, 2009 So on the ASUS P5K-E WiFi it should point to the nearest side of the case? [Antec P182] Link to comment Share on other sites More sharing options...
i_was_here Posted July 11, 2009 Share Posted July 11, 2009 The fan on the Zalman should be on the ram side, that way it blows air towards the rear of your case and your case fan then expels said air. It would look something like this: Link to comment Share on other sites More sharing options...
sc302 Veteran Posted July 11, 2009 Veteran Share Posted July 11, 2009 a good way to troubleshoot those noisy fans....stop them from spinning (put your finger on it, put a screwdriver between the blades, whatever you can do to stop it from spinning), if the noise stops good chance it is the fan that you just stopped. serious call to dell: Me: I need a new processor fan, it is making noise. Dell: How do you know you need a new processor fan? Me: I stopped the fan from spinning and the noise went away, when it started spinning again the noise came back. Dell: We are shipping you a new fan. Took longer to get my address to send it to than it took to troubleshoot the issue. Link to comment Share on other sites More sharing options...
WorkSpacer Posted July 11, 2009 Author Share Posted July 11, 2009 ^To simple!!! Great! The fan on the Zalman should be on the ram side, that way it blows air towards the rear of your case and your case fan then expels said air.It would look something like this: Awesome! Thanks, looks like my case!!! Link to comment Share on other sites More sharing options...
WorkSpacer Posted July 13, 2009 Author Share Posted July 13, 2009 Sh*t... finally got thermal greases, and now I've lost 1 of the screws... Any ideas, is 3 enough??? Link to comment Share on other sites More sharing options...
