How to run 7 in less than 512Meg
There were reports on this forum of running 7 in less than 512meg, I have an old notebook with 280meg, how can I make it install, it says 512meg is minimum.
Thanks
you will need a patched winsetup.dll & then reburn the iso. maybe you could try out with vista disc patched winsetup.dll, if that don't work just bing it up!
use a hexeditor to patch the winsetup.dll
Open it and Find 77073D7801 string
Modify to E90400000 and save the dll.
Now create a new DVD.
