the big dill Posted December 22, 2009 Share Posted December 22, 2009 Hello Everyone at Neowin! i have just switched to an internet service that costs more and provides less ;) lol i needed help on setting up my modem/router (Aztec DSL605EU) to work in bridge mode because my router that connects 3 other computer forces me to manually connect to the internet every time (user + pass) here is a pic of where i think is the place to set it up: What do i do from here? is this the right page? Any help appreciated! Cheers :D Link to comment https://www.neowin.net/forum/topic/857980-help-setting-modemrouter-into-bridge-mode/ Share on other sites More sharing options...
sc302 Veteran Posted December 22, 2009 Veteran Share Posted December 22, 2009 once you set it in bridge mode you will need to put in the pppoe settings within the router to "autoconnect" to the internet. wise ass comment: google is my friend, repeat this and you too will eventually be able to look up stuff. http://www.acanac.ca/docs/routersetup2007.pdf Link to comment https://www.neowin.net/forum/topic/857980-help-setting-modemrouter-into-bridge-mode/#findComment-592009148 Share on other sites More sharing options...
the big dill Posted December 22, 2009 Author Share Posted December 22, 2009 (edited) sc302 said: once you set it in bridge mode you will need to put in the pppoe settings within the router to "autoconnect" to the internet. wise ass comment: google is my friend, repeat this and you too will eventually be able to look up stuff. http://www.acanac.ca/docs/routersetup2007.pdf i have done those steps before with no solution... i get stuck on page 5 since it isn't for only my router... Edited December 22, 2009 by the big dill Link to comment https://www.neowin.net/forum/topic/857980-help-setting-modemrouter-into-bridge-mode/#findComment-592009154 Share on other sites More sharing options...
+BudMan MVC Posted December 22, 2009 MVC Share Posted December 22, 2009 Um step 5 is setting up your router - what you don't know how to put in PPPoE settings on your router? What router do you have? Link to comment https://www.neowin.net/forum/topic/857980-help-setting-modemrouter-into-bridge-mode/#findComment-592009334 Share on other sites More sharing options...
sc302 Veteran Posted December 22, 2009 Veteran Share Posted December 22, 2009 yes step 5 is for your router (linksys, dlink, netgear, etc) they should all have a pppoe setting. The pc's should not get touched, this is performed only at the router, as this sole router (as in one and only, no other router on the network if you have multiple routers) becomes the device that holds the connection open. the only reason to set up the aztech dsl router in bridge mode is to be able to port forward in your router behind the modem or to have your router behind the modem do some sort of vpn tunneling. Link to comment https://www.neowin.net/forum/topic/857980-help-setting-modemrouter-into-bridge-mode/#findComment-592009370 Share on other sites More sharing options...
the big dill Posted December 22, 2009 Author Share Posted December 22, 2009 sc302 said: yes step 5 is for your router (linksys, dlink, netgear, etc) they should all have a pppoe setting. The pc's should not get touched, this is performed only at the router, as this sole router (as in one and only, no other router on the network if you have multiple routers) becomes the device that holds the connection open. the only reason to set up the aztech dsl router in bridge mode is to be able to port forward in your router behind the modem or to have your router behind the modem do some sort of vpn tunneling. OOOOOOH - i was looking for this in the aztech router/modem configuration... thanks for the help i will see what i can do Link to comment https://www.neowin.net/forum/topic/857980-help-setting-modemrouter-into-bridge-mode/#findComment-592009424 Share on other sites More sharing options...
the big dill Posted December 22, 2009 Author Share Posted December 22, 2009 Thanks a lot for your help guys! i figured it out... Cheers! :) Link to comment https://www.neowin.net/forum/topic/857980-help-setting-modemrouter-into-bridge-mode/#findComment-592009522 Share on other sites More sharing options...
