MAVEЯiCK ☭ Posted May 23, 2010 Share Posted May 23, 2010 (edited) Well here is what happened. I know this shouldn't be posted in the Mac section; but I need opinion from Mac users. I had Hackintosh installed; but for some STUPID reason; I un-installed it; and installed Windows 7. So I had a project going on, that I edited .php files with Wordpad. I was writing the values (part of the PHP) in Cyrillic alphabet. So I saved the file, and... a total disaster. The Cyrillic alphabet was turn into questions (Почетна = ??????? --- for quick example). I lost all my 1 and a half hour. ****ty Windows :@ The don't even know how to implement UTF-8 technology in their Operative System. I'll install Hackintosh again, that's for sure... and this time; forever. And of course... I had to re-done the file, again. If i was on a mac it would only last 1 and a half hour. But on Windows, it was aprox. 3 hours! :s Edited May 23, 2010 by Colin-uk changed title. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/ Share on other sites More sharing options...
Doli Posted May 23, 2010 Share Posted May 23, 2010 php in wordpad... did you save as a plain txt document? and WHY Wordpad instead of Notepad? Cupcakes 1 Share Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592659768 Share on other sites More sharing options...
ToneKnee Posted May 23, 2010 Share Posted May 23, 2010 Who the hell writes PHP in Wordpad? Notepad maybe but why the hell didn't you use a basic PHP editor? Cupcakes 1 Share Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592659774 Share on other sites More sharing options...
Cupcakes Posted May 23, 2010 Share Posted May 23, 2010 On 23/05/2010 at 20:57, Doli said: php in wordpad... did you save as a plain txt document? and WHY Wordpad instead of Notepad? Same thing I was going to ask! A user's error is not a fault of the OS. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592659782 Share on other sites More sharing options...
bolerodan Posted May 23, 2010 Share Posted May 23, 2010 Ummmmm I hope this is just a joke/troll but you never write code in wordpad. Wordpad can append extra characters into the files as well that parsers will not like. This blows my mind. Sorry. Notepad++ or notepad2 anyone? As stated before. User error not OS error. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592659794 Share on other sites More sharing options...
-=Outlaw=- Posted May 23, 2010 Share Posted May 23, 2010 its not the OPERATING SYSTEMS fault, its the USERS fault. why in hell would you use WordPad to do PHP lol. i love when people blame stuff on things when in reality its their fault for not being smart enough Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592659806 Share on other sites More sharing options...
Neo003 Posted May 23, 2010 Share Posted May 23, 2010 Did windows told you that you can write php in wordpad heck even in notepad. If it did that you're right windows is stupid. You could you notepad 2 for editing php. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592659816 Share on other sites More sharing options...
Colin-uk Veteran Posted May 23, 2010 Veteran Share Posted May 23, 2010 Thread cleaned. please stay on topic, thanks. also, moved here Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592659848 Share on other sites More sharing options...
+jamesyfx Subscriber² Posted May 23, 2010 Subscriber² Share Posted May 23, 2010 Wordpad outputs tabbing and stuff better than Notepad if you open some php documents. I only observed this about 5-6 years ago though. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592659872 Share on other sites More sharing options...
fhpuqrgrpgvirzhpujbj Posted May 23, 2010 Share Posted May 23, 2010 http://www.urbandictionary.com/define.php?term=operator%20error Seriously use notepad. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592659902 Share on other sites More sharing options...
bolerodan Posted May 23, 2010 Share Posted May 23, 2010 On 23/05/2010 at 21:15, jamesyfx said: Wordpad outputs tabbing and stuff better than Notepad if you open some php documents. I only observed this about 5-6 years ago though. Thats why you use neither. Although notepad > wordpad. Notepad2 or notepad++ that supports proper formatting and syntax highlighting. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592659936 Share on other sites More sharing options...
hdood Posted May 24, 2010 Share Posted May 24, 2010 On 23/05/2010 at 20:50, MAVEЯiCK ☭ said: ****ty Windows :@ The don't even know how to implement UTF-8 technology in their Operative System. I understand your frustration, but you must understand that both Windows and an application like WordPad has a learning curve. On Windows, plain text normally does not mean Unicode. Maybe it does on OS X, but Windows is not OS X and does not attempt to emulate OS X behavior. This is something you have to learn. Windows itself, however, uses UTF-16 internally, and Unicode on Windows is a synonym for UTF-16. If you want to save UTF-16 in WordPad, you can. You simply select save as Unicode text document. Presumably you chose to save non-unicode text (an option that is important to have available to maximize compatibility.) As for UTF-8, WordPad probably does not support it, as WordPad is not a web editor and UTF-8 is of little value on Windows where the native text format is UTF-16. Notepad I think does have an option for UTF-8, as will text editors designed for web work. You can also find editors that support UTF-32, or whatever other encoding you can think of. It's about picking the right tool for the job. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592661348 Share on other sites More sharing options...
MAVEЯiCK ☭ Posted May 24, 2010 Author Share Posted May 24, 2010 You can't write PHP code in Notepad. And I am not writing PHP code, I am only editing it. I am against 3rd party software; like Notepad +. I also tried on Notepad, and what I had to do is copy the file from Wordpad (because in Notepad it looks unformated; and it won't work), than go to File > Save As... > UTF-8. Still OS X has better unicode support. I have some Cyrillic software installed on my Windows, witch are not displaying correctly. Damn. I can read Cyrillic only on Google Chrome, lol. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592661432 Share on other sites More sharing options...
what Posted May 24, 2010 Share Posted May 24, 2010 On 24/05/2010 at 08:43, MAVEЯiCK ☭ said: You can't write PHP code in Notepad. And I am not writing PHP code, I am only editing it. I am against 3rd party software; like Notepad +. I also tried on Notepad, and what I had to do is copy the file from Wordpad (because in Notepad it looks unformated; and it won't work), than go to File > Save As... > UTF-8. Still OS X has better unicode support. I have some Cyrillic software installed on my Windows, witch are not displaying correctly. Damn. I can read Cyrillic only on Google Chrome, lol. Quote of the century. Also, please stop abusing semi-colons. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592661450 Share on other sites More sharing options...
MAVEЯiCK ☭ Posted May 24, 2010 Author Share Posted May 24, 2010 On 24/05/2010 at 08:48, what said: Quote of the century. Also, please stop abusing semi-colons. Maybe I'm wrong. I don't know Windows very well, lol. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592661458 Share on other sites More sharing options...
+virtorio MVC Posted May 24, 2010 MVC Share Posted May 24, 2010 Use a proper text editor. Problem solved. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592661466 Share on other sites More sharing options...
hdood Posted May 24, 2010 Share Posted May 24, 2010 On 24/05/2010 at 08:43, MAVEЯiCK ☭ said: You can't write PHP code in Notepad. Yes, you can. It's just text. On 24/05/2010 at 08:43, MAVEЯiCK ☭ said: I am against 3rd party software; like Notepad +. Why? So you would rather use software that was not designed to do what you're trying to do, than simply download something that was? On 24/05/2010 at 08:43, MAVEЯiCK ☭ said: because in Notepad it looks unformated; and it won't work I suspect the problem you had was that the file you were editing came from an OS with different line break sequence than Windows uses. Notepad can't read those, while WordPad automatically converts them. Windows uses a carriage return and a line feed, while OS X uses only a line feed. Older versions of MacOS used just a carriage return. The reason for these differences is historical. On 24/05/2010 at 08:43, MAVEЯiCK ☭ said: Still OS X has better unicode support. I have some Cyrillic software installed on my Windows, witch are not displaying correctly. Damn. I can read Cyrillic only on Google Chrome, lol. No. Windows fully supports Unicode. If you have buggy software installed, then that is not Windows' fault, no matter how many lols you put in your post. It's also not Windows' fault that you made a mistake. Kpssst 1 Share Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592661510 Share on other sites More sharing options...
JRosenfeld Posted May 27, 2010 Share Posted May 27, 2010 In Note pad, when you click file/save as, notice the third option at the bottom that says 'encoding'? The default is ANSI, but the dropdown box gives UTF-8 as an option. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592675556 Share on other sites More sharing options...
+Dick Montage Subscriber² Posted May 27, 2010 Subscriber² Share Posted May 27, 2010 Quote You can't write PHP code in Notepad Oh man, crap... What have I been doing!? Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592675564 Share on other sites More sharing options...
The_Decryptor Veteran Posted May 27, 2010 Veteran Share Posted May 27, 2010 On 24/05/2010 at 07:47, hdood said: ... If you want to save UTF-16 in WordPad, you can. You simply select save as Unicode text document. Presumably you chose to save non-unicode text (an option that is important to have available to maximize compatibility.) ... I was having issues trying to get this working (Notepad + Notepad2 could read it, WordPad couldn't, etc.), it turns out WordPad will only read files as Unicode if they're UTF-16 LE with the Byte Order Mark, anything else is treated as ASCII (Big Endian reads in as random Unicode characters, nice to see it doesn't check stuff) That was mainly for my own benefit, Notepad is much smarter when it comes to the encoding (UTF-8, UTF-16, BE/LE with or without a BOM, etc.) Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592675626 Share on other sites More sharing options...
unknownsoldierX Posted June 1, 2010 Share Posted June 1, 2010 On 24/05/2010 at 08:50, MAVEЯiCK ☭ said: Maybe I'm wrong. I don't know Windows very well, lol. The only thing you've said in this thread that makes sense. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592691934 Share on other sites More sharing options...
zhangm Supervisor Posted June 1, 2010 Supervisor Share Posted June 1, 2010 On 27/05/2010 at 16:47, njlouch said: Oh man, crap... What have I been doing!? Obviously you've been doing the impossible. Someone award this chap a Nobel prize. Link to comment https://www.neowin.net/forum/topic/903894-problem-with-utf-8-in-wordpad/#findComment-592691992 Share on other sites More sharing options...
