+Xinok Subscriber² Posted October 23, 2010 Subscriber² Share Posted October 23, 2010 (edited) Firefox - Keep Cookies for Specific Websites About This Guide This guide will show you how to configure Mozilla Firefox to keep cookies for specific websites only and delete the rest. Why would I want to do this? This helps you to balance convenience, security, and privacy. It's convenient because it allows you stay logged into websites of your choosing. It also lets you keep cookies which store settings or opt-out cookies. It provides security because it will log you out of all other websites when you close the browser. It provides extra privacy from things like tracking cookies, which monitor your activities around the web. These cookies will be deleted everytime you close Firefox. Configure Settings First, you have to ensure a few settings are configured properly, else things may not work properly. If using Firefox 3.x, open Tools -> Options on the menu bar. If using Firefox 4.x, click the main menu and click Options. 1. In the Options dialog, click the Privacy tab. In the first dropdown menu, choose Use custom settings for history. 2. Look for the checkbox that says Clear history when Firefox closes. If this box is unchecked, then you can skip to step 4. But if this box is checked, then click the Settings button to the right. 3. In this dialog, make sure Cookies is unchecked and click OK. If this is not disabled, then Firefox will delete all cookies when closing the browser. So this option must be disabled. 4. Make sure the option Accept cookies from sites is checked. In the second dropdown, next to where it says Keep until, choose I close Firefox in that list. Choose Websites to Keep Cookies For Now that Firefox is properly configured, you just have to choose the websites which you want to keep cookies for. There are two different methods you can use. Method 1: Exceptions List Open up the Options dialog, click the Privacy tab, and click the Exceptions button. From this dialog, you can manually enter websites to keep cookies for. Type in the website you want to add, and click the Allow button. Method 2: Page Info Open up the website that you want to keep cookies for. Right click anywhere on the page and click Page Info. Alternatively, you can choose Tools -> Page Info. Click the Permissions tab. Under where it say Set Cookies, uncheck Use Default. To the right, choose to Allow cookies for this site. Extra Notes Firefox may not delete all of your cookies if your homepage is set to "Show my windows and tabs from last time". By following this guide, you are configuring Firefox to delete the cookies at the end of the session. When this is set as your homepage, it is resuming your previous session. I'm not sure why only some cookies are kept and others are deleted though. Nov 16 2010 - Added extra note about setting homepage Edited November 17, 2010 by Xinok s0rt3d 1 Share Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/ Share on other sites More sharing options...
FiB3R Posted October 23, 2010 Share Posted October 23, 2010 Great guide, thank you. :) Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-593299754 Share on other sites More sharing options...
SQ1 Posted October 23, 2010 Share Posted October 23, 2010 Thanks, this is why i love Firefox ;) Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-593299758 Share on other sites More sharing options...
ViZioN Posted October 31, 2010 Share Posted October 31, 2010 Great guide, going to check this out right now. Cheers! Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-593323682 Share on other sites More sharing options...
Jebadiah Posted October 31, 2010 Share Posted October 31, 2010 Excellent guide! Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-593323780 Share on other sites More sharing options...
Pupik Posted October 31, 2010 Share Posted October 31, 2010 There's no need to check "Clear history when Firefox closes". That step is useless for keeping the cookies. All you need to do is select the "Close Firefox" in the "Keep until:" selection and add the sites you want to keep the cookies of in the exception (mark them under "Allow"). When Firefox will be closed, it will delete all the cookies... except the ones marked under "allow". Here's a proper explanation from back 2008: http://www.neowin.ne...t__p__589534698 Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-593323868 Share on other sites More sharing options...
ambiance Posted October 31, 2010 Share Posted October 31, 2010 I just allow certain sites and block every domain. Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-593323878 Share on other sites More sharing options...
Rhialto Posted October 31, 2010 Share Posted October 31, 2010 I'm doing that for a long time already but there is something I would like to get rid of... Each time I visit a webpage with an imgxxx.imageshack.us I get a popup. I tried to enter *.imageshack.us as blocking but it does not work. Anyone know how to do that? Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-593324024 Share on other sites More sharing options...
+Xinok Subscriber² Posted October 31, 2010 Author Subscriber² Share Posted October 31, 2010 On 31/10/2010 at 12:33, Pupik said: There's no need to check "Clear history when Firefox closes". That step is useless for keeping the cookies. All you need to do is select the "Close Firefox" in the "Keep until:" selection and add the sites you want to keep the cookies of in the exception (mark them under "Allow"). When Firefox will be closed, it will delete all the cookies... except the ones marked under "allow". Here's a proper explanation from back 2008: http://www.neowin.ne...t__p__589534698 Some people are going to have this option enabled and want to keep it enabled. This is why I added steps 2 and 3, to ensure that this option doesn't delete your cookies. Step 2 hasn't changed, but I edited it a bit hopefully to make it clearer that if this box is unchecked, you can skip to step 4. Then step 4 tells you to do exactly what you said. On 31/10/2010 at 13:39, Rhialto said: I'm doing that for a long time already but there is something I would like to get rid of... Each time I visit a webpage with an imgxxx.imageshack.us I get a popup. I tried to enter *.imageshack.us as blocking but it does not work. Anyone know how to do that? What are you using to block popups from *.imageshack.us? You could try an adblock extension, but you'd have to block the URL of the popup itself, not the website that creates it. Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-593324598 Share on other sites More sharing options...
sullysnet Posted November 1, 2010 Share Posted November 1, 2010 Cookie Monster extension is great for this instead of these directions. Also easier :) l also use a clear history extension. Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-593328772 Share on other sites More sharing options...
Rhialto Posted November 2, 2010 Share Posted November 2, 2010 On 31/10/2010 at 17:31, Xinok said: What are you using to block popups from *.imageshack.us? You could try an adblock extension, but you'd have to block the URL of the popup itself, not the website that creates it. The popup I was talking about was about the cookie, like this one: Unless I block full imageshack.us I always get such pupop and I block them each time but img range from img0 to img999 so that's a lot to block. I tried to enter *.imageshack.us but it's a no go and like I said if I block imageshack.us it works but for the complete website while I was looking to use imageshack.us for my sessions and only block imgxxx (many of those when browsing here and there). Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-593332620 Share on other sites More sharing options...
Pupik Posted November 2, 2010 Share Posted November 2, 2010 By the way. Anyone knows how to achieve the same on Chrome? Because this is pretty much the only thing that stops me from switching to Chrome from Firefox, as my default browser. Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-593332796 Share on other sites More sharing options...
monkeylove Posted January 11, 2014 Share Posted January 11, 2014 I've switched from Chrome to Firefox, and I'm looking for an extension in Firefox that can do this easily. For Chrome, it's Vanilla Cookie Manager, as mentioned in the other thread. For the current version, it's very easy: when you visit a site, just click on the extension button in the address bar and select to whitelist the cookies of the site or of the domain. Prior to that, I used CCleaner, but I usually forgot to mark new cookies that I want to keep, so I decided to use the browser extension instead. Since I had a lot of cookies that I wanted to keep, I looked for the configuration file in CCleaner that contained the list of cookies to keep, then copied and pasted it in Vanilla. Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-596210231 Share on other sites More sharing options...
monkeylove Posted January 12, 2014 Share Posted January 12, 2014 I'm currently trying the Cookie Whitelist add-on. Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-596212049 Share on other sites More sharing options...
potwer Posted May 9, 2014 Share Posted May 9, 2014 thanks Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-596394959 Share on other sites More sharing options...
ptitrusse Posted January 15, 2015 Share Posted January 15, 2015 Hi Great guide, but not quite complete ! in step 3, you have to make sure that "Site Preferences" is unchecked too ("not just Cookies") mine was checked and I spent an hour trying to figure out why it didn't work! cheers! Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-596717868 Share on other sites More sharing options...
Neyht Member Posted January 15, 2015 Member Share Posted January 15, 2015 I have "accept third party cookies" set to either "always" or "from visited" else it breaks youtube commenting. Link to comment https://www.neowin.net/forum/topic/948016-guide-firefox-keep-cookies-for-specific-websites/#findComment-596717896 Share on other sites More sharing options...
