Cosmin Posted November 1, 2010 Share Posted November 1, 2010 Hy . I have a Nokia E72 model which brings me crazy. Even silent mode is not active there's no sound from it; only when someone tries to calls me instead of camera appears silent but cannot get it of it. Also tried ctr button & level up/down but no luck. Thanks for any suggestion. Link to comment Share on other sites More sharing options...
ehlo Posted November 1, 2010 Share Posted November 1, 2010 Have you tried updating the firmware with the nokia software updater as well as a hard reset (the hard reset codes can vary, but google will have the answer)? Link to comment Share on other sites More sharing options...
Cosmin Posted November 1, 2010 Author Share Posted November 1, 2010 Have you tried updating the firmware with the nokia software updater as well as a hard reset (the hard reset codes can vary, but google will have the answer)? Tried to hard reset but no luck.. after reset it has just the vibration and display's silence in bottom-right corner. It has no sound even when I restart it and this nokia logo is displayed .. I'm so disappointed :( Link to comment Share on other sites More sharing options...
