P!P Posted November 15, 2010 Share Posted November 15, 2010 I've decided I'd like to build a 6 monitor setup. I'm still deciding on the monitor, I'm figuring I'll spend about $200 a monitor. At that price, I'm hoping I can get a decent 22" or 23" monitor. I don't need help picking out a monitor but I've never purchased any monitor mounts or stands. I'd prefer to have a desktop stand but a wall mount would be acceptable. I did a quick search and found a couple but there's a huge price difference. I have no idea what makes a good or bad stand/ mount. Does anyone have any suggestions or experience with a 6 monitor mount? I've also considered going with a 4 monitor mount but I think I'd rather just get a 6 monitor setup. Link to comment Share on other sites More sharing options...
sw1tch.. Posted November 15, 2010 Share Posted November 15, 2010 Visidec are really good quality monitor stands which I have used in the past with no troubles at all. I would highly recommend them however they are sometimes expensive, then there is Ebay :). Visidec VFS-DV - You could purchase 3 of these and stand them next to each other to achieve the 6 monitor total Visidec VFS-Q - You should check out this one for a 4 monitor option Atdec have a range of mounting options as well. You can check out their site here. Edit - Oh, and pics when your finished or it didn't happen ;) Link to comment Share on other sites More sharing options...
P!P Posted November 15, 2010 Author Share Posted November 15, 2010 Edit - Oh, and pics when your finished or it didn't happen ;) Oh, trust me, I'll do it. Although, it will probably take me a few months to buy all the monitors and the stand. I'll probably buy 1 or 2 monitors at a time and the stand last. I'm a computer tech and I've worked with several stock traders that have 6 monitor setups. I've always been kind of jealous. Recently a lady who does CAD came in with 5870 Eyefinity came in and that's when I decided I wanted a 6 monitor. I don't really have use for the setup other than looking cool. ;) Thanks for the help. I hadn't thought of buying 3 dual monitor mounts. Link to comment Share on other sites More sharing options...
sw1tch.. Posted November 15, 2010 Share Posted November 15, 2010 No worries at all. It will be nice to see it once you have finished. Good luck with the build! I have always wanted a big setup like that and I would use every dam inch of it. One day.... /dreams ;) Link to comment Share on other sites More sharing options...
soulpatch Posted December 16, 2010 Share Posted December 16, 2010 I decided to upgrade my setup to a 6 monitor display about a month ago and I gotta tell ya, it's awesome. I am using an ergotech triple desk stand. It can handle my 23" screens with ease. They have options that mount to your desk as well but I wasn't crazy about the idea of putting holes in my desk. Check it out: http://www.ergotechgroup.com/products/heavy-duty-17-30-36/hex-3-over-3-lcd-desk-stand-63/ Is that the kind of thing you're looking for? Link to comment Share on other sites More sharing options...
Argote Posted December 16, 2010 Share Posted December 16, 2010 I decided to upgrade my setup to a 6 monitor display about a month ago and I gotta tell ya, it's awesome. I am using an ergotech triple desk stand. It can handle my 23" screens with ease. They have options that mount to your desk as well but I wasn't crazy about the idea of putting holes in my desk. Check it out: http://www.ergotechg...-desk-stand-63/ Is that the kind of thing you're looking for? Would you care to post a photo of your setup? Link to comment Share on other sites More sharing options...
soulpatch Posted December 17, 2010 Share Posted December 17, 2010 Sorry the picture is blurry but it's still pretty sweet Link to comment Share on other sites More sharing options...
