Cheers Louis for this, he has posted his NT Error codes and system build guide @ MaxReboot and let uis know that the first sections are up, this is what its all about:
Windows NT Error Codes List
This is first full length tutorial is available for this section, which is aimed at Beginners and Pros and explain about building or/and upgrading computer systems. It contains information on what to do before, while and after building your computer. Parts of this guide will also help you with a single aspect of computer system such as upgrading a single part or even the building of an entire computer. By the end of the guide people will start to see you as an expert when it comes to computer hardware.
Device Manager Error Codes List
The Device Manager is a tool in Microsoft Windows for administrating device drivers. These drivers control how the hardware within the computer interactive with the computer's operating system. Whenever there is a problem with a device driver or physical hardware component, this manager will show a code with a little description. But due to the limited nature of this description, this is why this guide has been created. It has a list what the full code means as well as offering a solution to the problem. You can use the Device Manager to view device, change device properties, update device drives, configure driver settings and if necessary uninstall these device drivers. Also by using this guide you should be able to solve any problem with you computer drivers or hardware components.
View: MR - Sniper section
