The September 2023 firmware update is now available for three more Surface devices: the Surface Book 3, Surface Go 3, and the fifth-generation Surface Pro (2017 model). The latest release improves battery life and LTE stability and resolves security vulnerabilities.
You can use the following links to quickly jump to the device you need:
Surface Book 3 | Surface Go 3 | Surface Pro 5
What is new in the Surface Book 3 September 2023 firmware update?
- Improves battery and power performance stability.
Windows Update Name | Windows Device Manager |
Dolby - Software Component - 3.30508.581.0 | Dolby APO SWC Device - Software components |
Surface - System - 3.100.139.0 | Surface Radio Monitor - System devices |
Supported Configurations | 13 and 15-inch Surface Book 3 |
Supported Windows Versions | Windows 10 version 21H2 and newer Windows 11 version 21H2 and newer |
How to get the update | Windows Update Surface Support website (manual installation) |
Update size | 1.7GB (manual installation only) |
Known Issues | No known issues in this update |
The Surface Book 3, Microsoft's once most powerful and quirky laptop-tablet combo, will remain supported until April 1, 2025.
What is new in the Surface Go 3 September 2023 firmware update?
- Improves LTE modem stability and GPS experience.
Qualcomm Technologies Inc. 2017 - Firmware - 23.20.4.48 | Surface Mobile Broadband Update Device - Firmware |
Supported Configurations | Surface Go 3 |
Windows 10 version 21H2 and newer |
Update Size | 558MB (manual installation only) |
Microsoft will continue releasing firmware updates with new drivers for the Surface Go 3 until at least October 5, 2027.
What is new in the Surface Pro 5 firmware update?
- This update addresses potential security vulnerability and improves system stability.
Surface - Firmware - 239.779.768.0 | Surface UEFI - Firmware |
Supported Configurations | Surface Pro 5 Surface Pro 5 LTE |
Update Size | 552MB (manual installation only) |
The fifth-generation Surface Pro and its LTE variant is the next Surface device to reach its end of life. According to Microsoft, support will end on January 15, 2024.
