The November 2023 firmware update is now available for the Surface Pro 9 powered by Intel processors. The latest release addresses screen rotation issues, fixes the "battery not genuine" error message, improves stability when connected to docks and external displays, plus patches the stuck Surface logo on boot.
Note: this update does not apply to the Surface Pro 9 with the Microsoft SQ3 processor.
What is new in the Surface Pro 9 November 2023 firmware update?
Addresses screen rotation issue.
Resolves "battery not genuine" notification.
Improves stability when attached to Surface Docks.
Improves external display connection stability.
Resolves a device booting to Surface logo issue.
Windows Update Name | Windows Device Manager |
Surface - Extension - 6.196.139.0 | Microsoft Devices Telemetry Service - Extension |
Surface - Firmware - 2.26.4.0 | Microsoft Surface Thunderbolt (TM) 4 Dock Firmware Update - Firmware |
Surface - Extension - 6.10.137.0 | Surface Dock 2 Firmware Update - Extension |
Surface - System - 6.204.139.0 | Surface Integration Service - System devices |
Surface - Firmware - 6.101.139.0 | Surface System Aggregator - Firmware |
Supported Configurations | Surface Pro 9 with Intel processors |
Supported Windows Versions | Windows 10 version 21H2 and newer Windows 11 version 22H2 and newer |
How to get the update |
Windows Update Note: Surface firmware updates are non-uninstallable, so back up important data before proceeding. |
Update Size | 741MB (manual installation only) |
Additional Steps | The update does not require additional steps before or after installation. |
Known Issues | The update does not contain known issues or bugs. |
Surface Pro 9 with Intel and ARM processors will be supported until October 25, 2028. It is Microsoft's current flagship Windows 11 tablet, and you can pick one starting at $999 on Amazon US or the Microsoft Store.
2 Comments - Add comment
